Home Racing World • View topic - Route 66 Rally/Raid layout.
SHOW YOUR SLOT CAR TRACK!
Postby downtowndeco » Tue Jun 25, 2013 9:53 pm
downtowndeco
Re: Route 66 Rally/Raid layout.
Postby racer6583 » Tue Jun 25, 2013 10:00 pm
Your track looks like it will be a lot of fun the scenery that you have looks good.
Thanks for sharing.
racer6583
Postby waaytoomuchintothis » Tue Jun 25, 2013 10:16 pm
Great job on the rock faces. Did you carve them in wet plaster or cast them?
Postby downtowndeco » Tue Jun 25, 2013 10:44 pm
Thanks guys. The rocks are cast plaster using rubber molds. I filled in the cracks using joint compound.
downtowndeco
Postby dreinecke » Wed Jun 26, 2013 6:16 am
Ah, one of my favorite builders up to no good I see! I cannot wait to see the next installment! The rocks are excellent looking!
Postby ListerStormGT » Wed Jun 26, 2013 6:46 am
Track is looking great so far, looking forward to watching the progress of this one!
Postby ourwayband » Wed Jun 26, 2013 11:16 am
Great looking rock walls!!I'm Looking forward to this Build.You have picked the perfect theme.Route 66..
Postby downtowndeco » Sun Jun 30, 2013 7:08 pm
downtowndeco
Postby Ember » Mon Jul 01, 2013 5:12 pm
What's your secret to getting your rocks out of the moulds cleanly? I've been experimenting with casting rocks from Noch moulds, but so many of the sharp edges that I like get left behind in the moulds. :(
I am having a little more luck with some soft latex brick wall moulds that I made myself.
Looking forward to watching you scenery unfold.
Have you considered using combed sisal for grasses? The Woodland Scenics field grass looks too fine in many cases.
Postby downtowndeco » Mon Jul 01, 2013 8:36 pm
Well, molds with deep cuts can be hard. I use hydrocal, which is a very hard casting plaster. I also spray the molds first with "wet" water, which is water mixed w/a few drops of liquid dish soap. Even then it can be hard to get perfect castings. Make sure you let them set up a good 30/45 minutes. Check out my companies, I work w/plaster all day long;
www.downtowndeco.com
www.dioramasplus.com
downtowndeco
Postby downtowndeco » Thu Jul 04, 2013 9:16 am
downtowndeco
Postby downtowndeco » Tue Jul 09, 2013 6:44 pm
downtowndeco
Postby dreinecke » Tue Jul 09, 2013 8:08 pm
Really great rock work! Very, very good indeed!
Postby downtowndeco » Tue Jul 09, 2013 10:00 pm
downtowndeco
Postby racer6583 » Wed Jul 10, 2013 11:04 am
Your track is coming along nicely.
How did you get your track to bend without kinking the power rails?
The more I looked at your track the more I wonder how you bend a plastic track without messing it up.
I like how you did your rocks and painted the scenery thus far.
racer6583
Return to Reader's Roads
