Guardrail alternative
SHOW YOUR SLOT CAR TRACK!
Postby Slotracing132.com » Sun Jan 11, 2015 4:07 am
First I have bought a 3 - wire ribbon cable and a round aluminum tubing from the hardware store. The aluminum tube I cut into 3.5 cm long items. Then I painted the items and the ribbon cable gray. Now I screwed 6 cm long screws through the plywood and chipboard. About this the cutted aluminium tubings were placed and glued with super glue. Final I glued the ribbon cable to the aluminium tubings and fixed with clothes pins. Alternative you can attach the cable to the aluminum tube pieces with small screws. Maybe someone wants to try it.
Slotracing132.com
Re: Guardrail alternative
Postby Slotracing132.com » Sun Jan 11, 2015 4:55 am
After several accidents you must rework !
But on account of the great optics that is not a problem for me.
Slotracing132.com
Postby btaylor » Sun Jan 11, 2015 5:39 am
Great Tip!, nice way to get guardrail in bulk form!
Postby racer6583 » Sun Jan 11, 2015 6:38 am
Thanks for the tip.
A great way to get a guardrail without alot of cost.
racer6583
Postby TuscoTodd » Sun Jan 11, 2015 8:08 am
I wonder if you used Krylon Fusion paint for plastic if that would minimize the potential for paint loss? But any way you cut it, that makes for some cool guardrail for a very reasonable price! I like it!
Postby Wolseley Hornet » Sun Jan 11, 2015 12:40 pm
Doesn't a bit of paint loss add to the "atmosphere"?
Really good idea!
David.
Wolseley Hornet
Return to Reader's Roads
