Carrera Digital parts question
Postby WaltB » Fri Jan 18, 2019 3:33 pm
I've decided to convert most of my analog cars to digital and am curious if the white plastic plugs and terminal ends used by Carrera are available in bulk anywhere?
I could hard-wire them , but difficult to swap from car to car.
Suitable LED's for headlights would be on my list also (and wiring tips for same) Cincyslots may have posted this before?
I'm capable of doing the installs ok, but finding the correct pieces online is daunting. I know I've seen this info here but haven't found it yet, so any help is very much appreciated.
Thanks, Walt :text-thankyouyellow:
WaltB
Re: Carrera Digital parts question
Postby WaltB » Fri Jan 18, 2019 6:28 pm
Found LEDs and some other pieces ok and wiring info on the web. Fairly simple with Digital.
Connectors are still an issue - Anyone know how small an EC2 connector from an RC car is? My nearest hobby store is 90 miles or I would go look
WaltB
Postby BARC 1 » Fri Jan 18, 2019 9:39 pm
Try searching micro connectors on ebay,
Postby buspor63 » Sat Jan 19, 2019 5:27 am
Cincy Slots recently advertised pairs for lights and motors.
buspor63
Postby WaltB » Sat Jan 19, 2019 12:33 pm
Thank you both
WaltB
Postby lancelotalove » Sat Jan 19, 2019 12:44 pm
Since you have lot of cars, you could order a bunch of plug and sockets (not sure what they are called) and cut the carrera one off and solder on the new ones. That would help you with the swapping of the chips.
The plugs for the lights are different type and different size than the motor plugs.
lancelotalove
Postby WaltB » Sat Jan 19, 2019 4:25 pm
Not sure 30 is a lot but they seem to multiply at night. Most are non lighted but some were - about 50/50
At $7 for a pair of leads that will add up pretty fast, need a more economical way. probably just get a selection of the 'bay and see what will work.
WaltB
Postby Broman62 » Sat Jan 19, 2019 6:26 pm
Try Carrera Slots website...(category)...132/124parts...1/32 pit stop...way towards bottom of list...hopefully this helps???
https://www.carreraslots.com/Merchant5/ ... de=LED3773
Postby 32lbking » Sat Jan 19, 2019 7:02 pm
It seems this thread is posted twice in the same forum. Anyhow, I posted ebay item #'s for the 2 different size connectors in the other thread. Sorry, I don't know how to post a link :?
Randy
32lbking
Postby Perrotoro » Sun Jan 20, 2019 6:41 pm
these work well for me: https://www.amazon.com/gp/product/B01MU ... UTF8&psc=1
Simply solder to the carrera 26732 chip light leads
Perrotoro
Postby Perrotoro » Sun Jan 20, 2019 6:53 pm
Ooops - I think your question pertains to these. Disregard post above.
https://www.amazon.com/gp/product/B013J ... UTF8&psc=1
Perrotoro
Return to Digital Racing
