Car not working...lights flash rapidly
Postby fourshipp » Wed Dec 26, 2018 11:17 am
One of my Carrera DTM cars went south last night. During a practice session after a deslot, when placed back on the track the lights started flashing very rapidly, about twice as fast as they do when programming or out of fuel. The car will not respond to any coding or other inputs, and it will not drive at all.
Any ideas? This is a new problem for me. Thanks.
fourshipp
Re: Car not working...lights flash rapidly
Postby b.yingling » Fri Dec 28, 2018 8:37 am
Try flipping the direction switch back and forth, along with placing the car back on the track the other way round a time or two. If you haven't already, you also might try turning the track on/off with the car on the track.
b.yingling
Postby fourshipp » Fri Dec 28, 2018 12:48 pm
Thanks, Bruce. I have tried flipping the switch and running reverse direction and that did not help. I have not tried cycling track power off and on with the car on the track. I will try that. What about resetting the CU?
Thanks?
Bruce
fourshipp
Postby fourshipp » Fri Dec 28, 2018 8:04 pm
No luck cycling power with car on track. I’ll swap chips next. Thanks.
fourshipp
Postby fourshipp » Sat Dec 29, 2018 12:41 am
Replaced the chip. Works fine now.
fourshipp
Postby b.yingling » Wed Jan 02, 2019 12:40 pm
I'm surprised by that one. I would not have bet the chip was bad. But I don't know if I've ever seen that exact phenomenon, either. I made the power/polarity suggestions just because I've used that to shock flaky cars/chips back to their senses in the past.
b.yingling
Return to Digital Racing
