Home Racing World • View topic - DC Power Supply and Carrera Digital
Postby fourshipp » Fri Dec 07, 2018 4:51 pm
I am building a 6x16 Carrera digital layout and want to use a separate digital DC power supply such as this.
I’ve seen both 5A and 10A models. What size is best?
How do you wire this into the Carrera control module. I have the newer style module built into a straight track section, not the black box.
Thanks.
Bruce
fourshipp
Re: DC Power Supply and Carrera Digital
Postby buspor63 » Fri Dec 07, 2018 5:18 pm
That's basically the one I have, 10A 30V. 7 amps are good for the control unit, which I think you said you have. I cut the cord off of the Carrera P/S and soldered it to the leads going to the after market P/S. Install a inline fuse holder on the positive side and use a 7 amp fast burn fuse.
buspor63
Postby fourshipp » Fri Dec 07, 2018 10:35 pm
Thanks. I can do all that. Easy peas lemon squeezy!
fourshipp
Return to Digital Racing
