Home Racing World • View topic - CU Sleep mode
CU Sleep mode
CU Sleep mode
Postby anthonyalonso » Thu Nov 15, 2018 2:17 pm
We tried Bruce's post of Power and Fuel button together for sleep and we get 2 separate beep tones and it stays in sleep mode. How do we toggle from sleep to not sleep?
Tom
anthonyalonso
Re: CU Sleep mode
Postby b.yingling » Fri Nov 16, 2018 8:35 am
b.yingling
Re: CU Sleep mode
Postby anthonyalonso » Fri Nov 16, 2018 8:29 pm
Hi Bruce and thanks for reply. Always great to get answers from you!! You are Very respected here!! After trying the Power and Fuel together it stayed in sleep mode. Then tried again and still stayed in sleep mode. I also somehow turned off the sound. Have not tried to reset. Not sure of firmware as we bought this CU used. Will try tonight and let you know. Club racers want your RMS program so we will be attempting to get that happening soon.
Tom
anthonyalonso
Re: CU Sleep mode
Postby edmagner » Mon Nov 19, 2018 5:13 pm
FYI - I tried this on a 5.327 firmware CU and it does not work - seems to be something that got done when the "old" sleep mode went away around 5.330
Ed
edmagner
Re: CU Sleep mode
Postby b.yingling » Mon Nov 19, 2018 5:47 pm
Ed: If you're using 5.327 doesn't a controller wake the CU from it's sleep? I would have no problem with the sleep mode being on if you could still revive the CU by pressing a throttle.
b.yingling
Re: CU Sleep mode
Postby edmagner » Mon Nov 19, 2018 7:35 pm
edmagner
Return to Digital Racing
