Cincinnati 4hrs of Le Mans June 16, 2018
Postby Cincyslots » Tue May 01, 2018 7:02 am
Carrera D124 Race Fans,
Once again Cincinnati will be hosting their 4hr hours of Le Mans. The race will take place June 16, 2018 at the home of local racer John. He has graciously opened up his track for us to use. If you are interested in racing or bringing a team, let us know by June 1st if possible. Team will consist of 2-3 racers. It depends on the # of racers involved.
The doors will open at 10am, tech inspection at 11:15 and racing to start around 12pm. We will have a running clock of 4 hours. The time will not stop for track calls. The cars to be run are the Ford GT, Porsche GT3, Corvette C6R/C7R, Ferrari 458/575/599, Mercedes SLS, Aston Martin and Audi R8 LMS.
The rules are:
BASIC RACE RULES
- The race will be a 4hr Enduro
- The clock does not stop.
- Track power will only be turned off for major crash where other cars can’t get by or unreachable by the marshal’s grabber.
-15-20min rotation is preferred but not mandatory. Drivers MUST driver equal time.
-You can only enter the race with 1 of the 2 cars that went through tech inspection
-If back up car is used, that team will be accessed a 2 lap “pit repair” penalty. The car will need to restart from the pits.
-Cleaning your braids, you can clean/change them as often as you want. You must drive the car into to the pit, pick it up, service it and place it back in the pits when it won’t interfere with traffic.
-Passing slower traffic. The faster car must make their way around slower traffic. DO NOT ram cars out of the way. Continuously doing so will result in 2 lap penalty
-Out of gas, try to notify other drivers when you are out of fuel to help prevent crashing.
-Pitting, call out your pit stop if traffic is behind you.
-Entering the race track after a pit stop, only enter when the track is clear.
RACE CAR RULES
- All traction magnets must be removed. Weight can be added. Car weight 210g-270g
- Wheels can be trued
- Stock Carrera wheels must be used
- Tires can be trued
- Silicone tires to be used on rear axle
- Front tires can be super glued/clear coated on thread
- Tires can be glued onto the rim
- Gear ratio to remain stock using stock Carrera gears 10/50 (No aftermarket gears allowed - i.e. Slot.it, NSR, etc...)
- Stock Carrera D124 motor (Race will be run at 17.5 Volts at the track)
- Axle carriers to remain stock – axles have to run in stock bushings – no ball bearings allowed
- Must use stock Carrera guide flag
- No suspension allowed
- No body/chassis alterations or modifications of any kind (Filing, shaving, channeling etc.)
- Factory interior must remain intact and complete
- Body must be mounted with all factory screws
- No alteration to body or chassis in order to achieve body float
- Stock guide arm
- All lights need to be functioning during tech inspection
PLEASE TAKE RULES AT FACE VALUE. We are not a group that looks favorably on bending the rules :thumb:
Cincyslots
Re: Cincinnati 4hrs of Le Mans June 16, 2018
Postby Cincyslots » Tue May 01, 2018 7:26 am
That didn't take long. I can't wait to catch up with you Kurt Moser. Hopefully we can get a couple more out of towners to come race.
See you soon,
Bruce
Cincyslots
Postby JamieB » Tue May 01, 2018 4:33 pm
Looking forward to it! This is always a fun event!
JamieB
Postby Cincyslots » Thu May 03, 2018 4:32 pm
Sweet! We are nearly full!
Cincyslots
Postby Cincyslots » Thu May 17, 2018 1:30 pm
AWESOME!!!! We have filled out our 6 car field for the 4hr of Silicone Valley. 15 racers from 3 states. This is shaping up to be another fun filled event. We'll post pics and videos later.
Bruce
Cincyslots
Return to Digital Racing
