Carrera 1/32 Digital (need help with track layout)
Re: Carrera 1/32 Digital (need help with track layout)
Postby martin0409 » Tue Nov 19, 2013 5:52 pm
Hello again gentlemen. 3 have two questions which I hope you can help me out.
1. I will have 4 lane change sections in all (2 right, 2 left). Can I use them all in the track layout.
2. Can I use both the Control Unit and Black box in the track layout and be able to use the wireless controller and wired contoller at the same time or alternately.
3. Can I run analog cars in the layout. If not how will I go about doing it.
I thank you all with your responses to my question
Best Regard
Martin
martin0409
Postby R/TRandy » Tue Nov 19, 2013 9:41 pm
Martin,
You will be able use the 4 LCs in your layout with no problems.
You can only use The CU or the BB not both, it could cause a short, also only use one power supply.
You can use all 4 controllers, you will have to plug the wireless receiver in to controller port one or two and program the wireless controllers to 1 and 2. Then plug the two wired controllers into controller ports 3 and 4.
Analog cars can not be used on a digital the layout, with digital the track has full power to it all the time. An analog car placed on the layout will have full power and race down the track and crash.
It is possible to make a modified digital/analog hybrid track, there have been posts about how to do it on other forums. But it is not a plug and play deal, you will have to open up the CU or BB. I only run digital, so I don't know all that is evolved. Maybe someone will chime in that has some info on it. Or you could chip the analog cars.
Randy
R/TRandy
Return to Digital Racing
