Variable voltage power supply
Re: Variable voltage power supply
Postby kidvoltage » Wed Oct 31, 2018 9:54 am
Yup, what he said. We run at 16.4 V and control car power via the control unit. And we run non-mag with urethane tires.
kidvoltage
Postby Perrotoro » Fri Nov 02, 2018 6:49 am
Thanks all very much!
I'll keep the magnets in and just use the control unit settings to set a max that will keep them "mostly" slotted as suggested, I tried even lower CU settings with no magnets and the "drifting" dynamic would cause even more issues.
Thanks again - don't know what I'd do without this site!
Perrotoro
Postby anthonyalonso » Fri Nov 02, 2018 11:49 am
We just purchased the same power supply. What is start up procedure? Do we turn on power supply first and set volts and amps and then turn on CU or what? Do we even have to set amps or does the CU take what it needs (amps) with voltage set at 18v. We run 4-6 124 cars.
Tom
anthonyalonso
Tom
anthonyalonso
Postby dw5555 » Sat Nov 03, 2018 9:00 am
Tom turn on the power supply and set it to your required voltage. With the amp dial I just set mine in the middle since there is no way of knowing what it is without a draw on it. The CU will limit the amps to what it needs. Once it's set your good to go just turn on the CU and your off and running.
Dave
dw5555
Postby anthonyalonso » Sat Nov 03, 2018 9:13 am
Thanks DW
We set the volts at 20 and the amps we turned the knob all the way up with a inline 7.5 amp fuse. With the old Carrera Power pack we was measuring rail voltage at 15.87 but with this aftermarket unit turned up to 20volts we are getting 17.96 volts from the rails. What a difference.
Tom
anthonyalonso
Postby dw5555 » Sun Nov 04, 2018 9:02 am
Yep fuse will work..
Dave
dw5555
Return to Digital Racing
Users browsing this forum: No registered users and 21 guests
