SCCOTTT Horseheads NY
Post Your Club/Home Info Here
Postby Van Duzer » Thu Sep 22, 2016 11:32 am
It that time of year for the Slot Car Club of the Twin Tiers Team Enduro. Just as last year we are using the Slot-it GT 40 and will be racing both the Carrera plastic and the Pipher Glen wood track.With our new Computer race program we will have pit stops for fuel. You can enter your own team or join one of ours. The rule are posted here and this year I even read them.
1/32nd Slot.It GT40 Team Enduro
October 15, 2016
Rules & Information
Eligible Cars: 1/32nd scale GT40 manufactured by Slot.It.
Race track: 1/32nd scale Piper’s Glen road course (routed wood) and VanDuzer International (Carrera)
Race format: Team race
Team Entries: Team entries are limited to the first 7 teams to sign up. Teams should signup prior to the event with a team name, team captain and the team members that you already have.
Extra Drivers: Drivers who wish to join a team should do so prior to the event.
A list of teams with drivers should be available prior to the event.
Rules: See Below
Race fee: $10 per person.
Race Date: October 15, 2016
Schedule: Friday 14th Practice night 6:30pm to 9pm
Saturday 15th Practice starts @: 9:00am
Prerace Tech @: 12:00pm
Racing starts @: 1:00pm
Directions: Take NY Interstate 86 (formerly Rt.17) to Horseheads Exit 53.
Turn south onto Grand Central Avenue.
On the right - look for (in order) Burger King, Wendy’s, Pizza Shop, 2 white houses.
Our club is in the back of the second of these 2 white houses on the right.
There is parking out front and also out back via the driveway on the left of the house.
Extra Practice – Prior to October 15, extra practice time is available during our open nights or by special appointment. We should be able to set up an extra practice session at your convenience as long as we get enough notice. Contact us via Email – vanduzer1@yahoo.com
Questions – If there are any questions regarding the rules or information about this race,
please contact us at – vanduzer1@yahoo.com
1/32 Slot.It GT40 Team Enduro– revision September 2015
1. All “SCCOTTT General Rules” apply except when superseded by a specific rule in this document.
2. Eligible Cars – 1/32nd scale GT40 manufactured by Slot.It.
3.Car Setup
A. Tires – The front tires must be Slot.It stock GT40. The rear tires must be the Slot.It F22 tires (#1207) made for the 15x8 wheels. SCCOTTT stocks these tires.
· The tires must be inside the widest portion of the fenders.
· Tires may be trued, shaped, sanded and narrowed.
· Tires may not be glued or conditioned.
· Tire outside diameter may not be coated with anything ( ie: paint, glue, etc.)
· Note: Tires must be dry before running on the track.
B. Parts – Unless otherwise specified in these rules, all parts must be Slot.It GT40 Box-stock.
· Any spacers are allowed to shim the wheels and gears for proper fit.
· Chassis body-post washers and pod washers may be removed and/or added
· The pod outer EVO screws may be removed
· The plastic wheel inserts are mandatory.
· The eyelets that hold the motor wires into the guideflag may be replaced with small screws.
· Stock Orange endbell Slot.It motor and stock gearing (32T/11T).
· Aftermarket braid may be used if similar to Slot.It copper or plated copper.
· Magnets must be removed.
C. Modifications/Tuning
· Weight may be added, but not removed unless specifically stated. The added weight must be securely fastened inside the car.
· Body cosmetic changes are allowed (painting, strips, stickers, etc.). No significant added or removed bodywork. These modifications are to serve no other purpose.
· Small breakaway parts need not be installed and/or replaced. (Mirrors, pipes, etc.)
· Light kits are allowed to be installed. Modifications can be made to the car to install the light kits. These modifications are to serve no other purpose.
· Normal Tuning is allowed (Braid adjustments, body/chassis loosening, etc.)
· The front axle adjustments are allowed by using the height blocks and/or setscrews in the supplied holes top and bottom.
· Braid “juice” is not allowed. (If the braids have been previously treated with braid juice, they are not allowed.)
Note: If there are any questions about any of the rules, please ask a SCCOTTT official.
TEAM RULES:
1.Team Car - Only one car is allowed per team.
2.Teams - Each team consists of 2 or more drivers (3 or more is recommended).
3.Driver Changes - Teams may change their driver as often as desired during a segment. (Please be respectful of other teams by trying not to block their view). Each team member should get a significant amount of driving time. Teams who have members doing the majority of the driving are discouraged.
4.Team Marshal - Each team is required to provide at least 1(one) track marshal at all times.
RACE RULES:
1.Pre-race tech. – Prior to the start of the racing, each car entry will go through a pre-race tech consisting of a visual inspection based on the car rules. Cars will be impounded before the race.
2.Race – Each team will run each lane for the specified length of time and for the specified number of rotations with a brief intermission in between. The segment length and number of rotations will be determined the day of the race.
3.Dry Tires and Braids – The cars’ tires and braids must be dry at all times when on the track. Tire “goop” is not allowed. Braid “juice” is not allowed. (If the braids have been previously treated with braid juice, they are not allowed.)
4.Maintenance & Repairs - All work to the cars is to be done “on the clock” during the race. Major car repair should be taken to the team “garage” area. If glue is used for repairs, it must be completely dry before the car goes back onto the track. Breakable parts (mirrors, wipers, etc.) do not need to be present/repaired/replaced.
5.Parts Replacement - All parts can be replaced except for the Body. If replacing the chassis, you must use the motor, gears, wheels, axles, tires, pod and guide from the old chassis.
6.Intermissions - During the intermission periods (~5 min. each) between segments, only the following work is allowed:
· changing the car lane and sticker
· braid adjustments
The team driver’s controller is also connected to the appropriate lane for the next segment. (All other work must be done “on the clock”.)
7.Track Calls - Once the race starts, it will only be stopped for a track call due to marshal damage or for cars which land on the floor.
8.Missed Laps – Due to the nature of this event, it is difficult to accurately account for any missed (uncounted) laps. We will do our best to account for missed laps, but there is no guarantee.
9.Post-race tech. – At the completion of the race, all cars will be impounded for a post-race tech consisting of a teardown inspection for adherence to the rules. One car at a time will be tech’d according to the finishing order 1st thru 4th. A representative of each team will be asked to dismantle their car for inspection by the officials.
Van Duzer
Users browsing this forum: No registered users and 36 guests
