score rules
Post Your Club/Home Info Here
score rules
Postby slotguy » Fri Dec 27, 2013 5:29 am
Hi does anyone know where to get the rules the guys that run the score series use. Tring to get a sprint car series going on long island and would like to know the motor and rear size tires they use. Thanks for any help .. Tony
slotguy
Re: score rules
Postby Lancaster Tornado! » Fri Dec 27, 2013 9:18 am
Here you go! hope this will be of some help to get your deal up and running!
Lee
SPRINT CAR SPECIFICATIONS
FRAME
Parma brass or steel Womp or Sprint Plus in line only. The frame may not be altered or modified in any way except to narrow the sides and to lengthen the front end by means of an extension plate.
The wheelbase shall be a minimum of 3 3/8″ and a maximum of 3 5/8″. Maximum width of the frame behind the front axle tab will be 9/16″ measured each side of the center line of the frame. The center line is defined as the line following the armature shaft of a mounted motor through the center of the front guide hole. No off-set frames allowed.
ROLL CAGE
The rear loop of the cage must be 1 3/4″ high measured from the top side of the frame. The opening above the driver must be at least 7/8″ by 7/8″. Brass thickness must be 1/16″ for the main components in the driver area.
NERF BARS
Each side of the car must have one nerf bar not extending more than 3/4″ beyond the side edge of the frame. At no time
may a nerf bar extend beyond the outer edge of a rear tire. Must be made of either 3/64″ or 1/16″ rod or tubing.
BUMPERS
Front bumper is optional, however, it may not extend in front of the center of the guide post and may not be made of rod or tubing larger than 1/16″ thickness. Rear bumper must be made of 3/64″ rod or tubing and is mandatory.
LENGTH
Maximum length of the car may not exceed 6 3/4″ measured from the front tip of the guide flag to the rear bumper.
WIDTH
The width of the car will be 3″ maximum measured from the outside edges of the wheel/tires on each axle. No wheel/tire may extend farther than 1 5/8″ from the center line.
BALL BEARINGS
Ball bearings may not be used anywhere on the car.
BODY
Hood and tail must be made of either lexan or plastic only. Hood must be mounted at least 1/4″ below cross bar of roll cage.Top of tail must be at least 1 1/8″ above top side of frame. Tail must extend at least 1 1/4″ behind rear edge of rear axle. Both hood and tail must be mounted securely and painted. Tail must be numbered. The hood must extend beyond the front axle and must be tapered to a maximum of 1″ at that point.
DRIVER FIGURE
Driver figure must be painted and be mounted below the top bars of the cage.
MOTOR
All cars must use the Falcon 1 motors that are available from the limited supply of SCORE. The orange product label must be intact and the motor must remain factory sealed. Re-magnetizing (“zapping”) motors is strictly forbidden.
TIRES
All rear tires must be at least 1-1/16″ in diameter and no more than 13/16″ in width. All silicone coatings must be readily available retail products and are subject to the approval of the Race Director. At no time may any product other than Twinn-K or Castrol Super Clean be used to clean a tire. Front tires must be at least 7/8″ in diameter and between 1/4″ and 1/2″ in width.
WEIGHTS
All weights must be secured below the frame or underneath the body so that when the car is viewed from above no weights or tape are visible. A 1/16″ ground clearance must be maintained below the car.
GEARING
Gearing is unlimited, however, no gear may infringe upon the 1/16″ ground clearance.
WINGS
Wings are not allowed.
GENERAL
All cars must have the appearance and proportions of an authentic scale (1/25th – 1/24th) Sprint car. Any questions concerning the eligibility of any car should be made to the race director well in advance of any competition.
Last edited by Lancaster Tornado! on Fri Dec 27, 2013 9:22 am, edited 1 time in total.
Lancaster Tornado!
Re: score rules
Postby Lancaster Tornado! » Fri Dec 27, 2013 9:19 am
DIRT CHAMP CAR SPECIFICATIONS
FRAME
Parma brass or steel Womp, FCR or Sprint Plus in-line only. The frame may not be altered or modified in any way except to narrow the sides and to lengthen the front end by means of an extension plate.The wheelbase shall be a minimum of 3 7/8″ and a maximum of 4 1/8″. Maximum width of the frame behind the front axle tab will be 9/16″ measured each side of the center line of the frame. The center line is defined as the line following the armature shaft of a mounted motor through the center of the front guide hole. No off-set frames allowed.
ROLL CAGE
NERF BARS
Each side of the car must have one nerf bar not extending more than 3/4″ beyond the side edge of the frame. AT NO TIME
MAY A NERF BAR EXTEND BEYOND THE OUTER EDGE OF A REAR TIRE. Must be made of either 3/64″ or 1/16″ rod or tubing.
BUMPERS
LENGTH
Maximum length of the car may not exceed 7 1/4″ measured from the front tip of the guide flag to the rear bumper.
WIDTH
BALL BEARINGS
BODY
Hood and tail must be made of either lexan or plastic only. Hood must be mounted at least 1/4″ below cross bar of roll cage.Top of tail must be at least 1 3/8″ above top side of frame. Tail must extend at least 1 1/4″ behind rear edge of rear axle. Both hood and tail must be mounted securely and painted. Tail must be numbered. The hood must extend beyond the front axle and must be tapered to a maximum of 1″ at that point.
DRIVER FIGURE
MOTOR
All cars must use the Plafit PL8631 “Cheetah II” Mabuchi motor. All motors must maintain their factory identification markings. Any motor without those markings will be disallowed and the motor must remain factory sealed. Remagnetizing (“zapping”) motors is strictly forbidden.
TIRES
WEIGHTS
GEARING
WINGS
GENERAL
All cars must have the appearance and proportions of an authentic scale (1/25th – 1/24th) Dirt Championship car. Any questions concerning the eligibility of any car should be made to the race director well in advance of any competition. The race director will approve or disapprove each car.
Lancaster Tornado!
Re: score rules
MIDGET SPECIFICATIONS
FRAME
Only Parma Womp (brass or steel) in line frames may be used. The frame may not be altered of modified in any way except to narrow the sides. Maximum width of the frame shall be 9/16” each side measured from the center line of the frame (excluding the front axle tabs).
The center line is defined as the line following the armature shaft of a mounted motor through the center of the front guide hole. The wheelbase must be 3″.
ROLL CAGE
The rear loop of the cage must be at least 1 5/8” high measured from the top side of the frame. The opening above the driver must be at least 7/8” by 7/8”.
Brass thickness must be either 3/64” or 1/16” for the main components in the driver area.
NERF BARS
Each side of the car must have one nerf bar not extending more than 3/4″ beyond the side edge of the frame. AT NO TIME MAY A NERF BAR EXTEND BEYOND THE OUTER EDGE OF A REAR TIRE. Must be made of 3/64″Brass.
BUMPERS
Front bumper is optional, however, it may not extend in front of the center of the guide post and must be made of 3/64″ Brass. Rear bumper must be made of 3/64″ Brass and is mandatory.
LENGTH
Maximum length of the car may not exceed 5 3/4″ measured from the front tip of the guide flag to the rear bumper.
WIDTH
BALL BEARINGS
BODY
Hood and tail must be made of either lexan or plastic only. Hood must be mounted at least 1/4″ below cross bar of roll cage. Top of tail must be at least 1″ above top side of frame. Tail must extend at least 1″ behind rear edge of rear axle. Both hood and tail must be mounted securely and painted. Tail must be numbered. The hood must extend beyond the front axle and must be tapered to a maximum of 1″ at that point.
DRIVER FIGURE
MOTOR
Must use Fox 10 motor. Motor must be installed with the manufacturer’s specifications up. Pinion gears will be limited to a maximum of 9 teeth.
TIRES
All rear tires must be a maximum of 15/16″ in diameter and a maximum of 13/16″ in width. All silicone coatings must be readily available retail products and are subject to the approval of the Race Director. At no time may any product other than Twinn-K or Castrol Super Clean be used to clean a tire. Front tires must be at least 3/4″ in diameter and not more than 7/8″ in diameter. The width of the front tires must be at least 1/4″ and not more than 1/2″.
WEIGHTS
All weights must be secured below the frame or underneath the body so that when the car is viewed from above no weight or tape is visible. At no time may any weight or tape drag upon the track surface.
GEARING
Is unlimited, however, no gear may drag upon the track surface.
WINGS
CONTROLER
Effective February 1,2012. Controllers for the midget division will be limited to standard Parma controllers. No other controllers may be used. No controllers with adjustable ohms/ brakes/ micro switches, etc. may be used.
GENERAL
All cars must have the appearance and proportions of an authentic 1/25th – 1/24th scale USAC midget. The Race Director will approve or disapprove each car. Any questions concerning the eligibility of any car should be made to the race director well in advance of any competition.
Lancaster Tornado!
Re: score rules
Postby Lancaster Tornado! » Fri Dec 27, 2013 9:21 am
COMPETITION GUIDE
SCale Open-wheel Racing Enthusiasts (SCORE) was created in 1995 in order to continue the area’s open wheel slot car tradition It is the intent of SCORE to provide a fair and competitive format for enthusiasts who enjoy racing Sprint, Midget, and Dirt Champ cars.
Participants should become familiar with the contents of this guide in order to understand the procedures that will be used during SCORE events. Whenever there is a question concerning a rule or procedure, it shall be the responsibility of the competitor to seek clarification from the Race Director.
The Race Director shall have the final decision in the interpretation of any rule,regulation, or procedure expressed, implied, or omitted. Any rule or procedure may be altered by the Race Director due to unusual circumstances or special programs.
It should be remembered that SCORE activities are meant to be enjoyable experience for all participants who wish to test their competitive skills, therefore, participants shall be expected to act in a sportsmanlike manner at all times.
A.WARM UPS
Competitors shall use the warm-up period before the event to make their final adjustments to their cars. Once the event has started, there shall be no long delays due to any car having mechanical problems.
B.STARTING ORDER
1.The starting order on the scorers’ sheet list all drivers in attendance, top to bottom, by:
a.Reverse order of the finish of the prior feature event in the division followed by:
b.Drivers who have points in the division, highest to lowest, who missed the prior feature followed by:
c.New drivers in the division.
2.All races shall be run in rotation. After the initial segment, the starting field shall rotate one lane towards the outside. Drivers from the bottom of the starting order and thereafter upwards on the list shall enter the rotation on lane one. The race shall be completed when all competitors have run each designated lane.
C.RACES
1.With the exception of special events,the Sprint and Midget divisions shall run 10 lap segments and the Dirt Champ division 15 lap segments.
2.All segments shall have a 4 wreck limit.
3.Restarts after a wreck shall be on the portion of the track where the wreck occurred. The field will be realigned, nose to tail, in the running order when the wreck occurred with all cars out of their lanes going to the back of the field. During the final two laps of each segment, however, the race will be under the TWO LAP RULE in which cars will not be realigned when the power is turned off for a wreck except where a car has drifted past another still in its proper lanes. Such a car will be repositioned behind the first car it had passed in that manner.
4.The TWO LAP RULE shall begin when all un-lapped cars have crossed the start/finish line for two laps to go in the segment.
5.The segment shall be considered completed when all cars have finished the scheduled number of lanes.
D.WRECKS / PIT STOPS
1.Any car / driver that has caused the power to be shut off, either for a week or stopping on the track during a green flag lap, will be given a wreck.
2.At no time may a driver make an adjustment to his car during a race except:
a.to fix a wire broken at the guide
b.when his/her car exit the track during a wreck. Then, the driver shall have 1 minute to brush off the car’s tires and make any repairs that do not require the car to be taken away from the track. After 1 minute the race will be restarted.
3.Elementary tasks such as adjusting the guide brushes, removing a weight, etc. that do not require more than momentary attention may be done by a turn marshal.
4.No motor or gear changes may occur during a segment. Any car blowing a motor or suffering extensive damaged due to a wreck will be considered to have wrecked out of that segment.
5.Any car losing a part that remains on the track surface and is deemed hazardous by the starter will cause the power to be shut off. The offending car will be charged with a wreck.
6.No part of a car may drag upon the track or interfere with another car’s ability to complete. If a turn marshal cannot remove the part, the driver must take a pit stop to correct the problem. The driver will be given 1 minute and will be charged with a wreck.
7.If the Starter mistakenly or accidentally turns off the power, the race will revert to the running order of the last completed and the field will be restarted at the start / finish line.
E.OVERVIEW
1.Once a race has officially started, it is the Race Director’s responsibility to insure the event is completed without significant delays. Since most participants have considerable drives to and from the track, it is important that the program is run as efficiently as possible.
2.All competitors are expected to perform duties such as turn marshals,starter, scorer, etc. when they are not racing.
3.Competitors are strongly urged to pay attention to the scorer when wrecks and finishing positions are called for. All questions concerning the scoring of a segment must be rectified before the start of the next segment.
F.F ) POINTS
1.Drivers not finishing a race or segment for any reason will have been considered to have wrecked out. Drivers not tacking the green flag in any race or segment will receive no points for that portion of the event. Drivers entering a segment after the initial green flag will do so “on the bubble”.
2.Segment points are determined by subtracting the number of wrecks from the points the driver earned for his/her respective finish ( 1st – 10 pts., 2nd – 9, 3rd – 8, 4th – 7, 5th – 6 ).
3.Race points shall be the total of each driver’s segment points. The driver with the highest race point total will be designated as the winner of the event, the second highest total will earn second place, etc.
4.Tie – breakers for the final positions shall be , in order:
a.wreck total
b.segment wins
c.segment wins without a wreck
d.second place finishes
e.second place finishes with out a wreck
f.Third place finishes
g.etc.
h.THE SYSTEM SHALL BE APPLIED,AFTER USING POINT TOTALS, IF ALL COMPETITORS INVOLVED IN A TIE SHOULD REMAIN EVEN AFTER THE ABOVE CRITERIA,THEN THE SYSTEM SHALL BE APPLIED TO THOSE SEGMENTS ONLY IN WHICH THE DRIVERS SHARED THE TRACK AT THE SAME TIME.
5.Event points:
1st place – 50 points
2nd place – 45 points
3rd place – 40 points
4th place – 35 points
5th place – 30 points
6th place – 28 points
7th place – 26 points
8th place – 24 points
9th place – 22 points
10th place – 20 points
11th place – 19 points, etc.
6.Attendance points – each driver taking the green flag in a divisional race will be given 5 points in addition to his/her event points.
7.Points for missed events:
A driver missing a race will be given his/her point total average after earning points in a minimum of three events. Attendance points will not be used in figuring the point average. A driver may receive his/her point average for a missed race only once per season per division.
Lancaster Tornado!
Re: score rules
Postby slotguy » Fri Dec 27, 2013 1:45 pm
Thanks for the info looks like a lot of reading to do
Tony
slotguy
