Re: Loctite GO-2 Glue
PostPosted: Thu Feb 06, 2014 12:50 pm
by RazorJon
thanks Dave
I have gotten glue on so many glass parts, its the part of building I hate.
I will give this a try, if it works you get a cookie :text-bravo:
PostPosted: Thu Feb 06, 2014 3:02 pm
by HRWJim
This is great. I was looking for a good glue for body mounts. Thanks Jim
PostPosted: Thu Feb 06, 2014 8:36 pm
by TuscoTodd
Appreciate the heads up! Will have to see about snagging some of that to try! :)
PostPosted: Mon Feb 24, 2014 7:40 pm
by JML
I ran across this stuff yesterday, but read the online info from Loctite. It seems it is not recommended for styrene plastics. The site says, "Not for use on polyethylene (PE), polypropylene (PP), polytetrafluoroethylene (PTFE), ABS and rigid polystyrene."
Anyway, an alternative I've found to be great is GS Watch Crystal Cement, which has a great needle applicator built into the tube:
http://www.micromark.com/watch-crystal- ... ,7468.html
PostPosted: Mon Feb 24, 2014 7:56 pm
by dreinecke
Good to know. I ONLY use Modge Podge or Tacky Glue any more on my windows though. Dries clear with no harm to the part or the body. Easy to remove later if needed, and I've never had a glass part pop out. Does take at least an hour to dry properly though.
