thanks Dave I have gotten glue on so many glass parts, its the part of building I hate. I will give this a try, if it works you get a cookie :text-bravo:
I ran across this stuff yesterday, but read the online info from Loctite. It seems it is not recommended for styrene plastics. The site says, "Not for use on polyethylene (PE), polypropylene (PP), polytetrafluoroethylene (PTFE), ABS and rigid polystyrene."
Good to know. I ONLY use Modge Podge or Tacky Glue any more on my windows though. Dries clear with no harm to the part or the body. Easy to remove later if needed, and I've never had a glass part pop out. Does take at least an hour to dry properly though.
