by waaytoomuchintothis » Fri Jan 17, 2014 12:23 am
Yeah, there's a balancing act you do with them. If its something you just can't screw up, then you move forward, but for things that can suffer from CCS Syndrome*, you really have to walk away rather than experiment with them. Oddly, a good deal of their machinist's tools are not bad at all, and they certainly beat MicroMark's prices. But I still get nervous about it and check them out more than anybody else. They change over time. I used to use their 18v drill/screw guns, because they were cheap and I went through them pretty fast when building cabinetry in some big construction sites (big grocery stores, etc.). Over a period of about four years, the drills went from pretty dang good to unusable junk with planetary gears that were made of plastic, and motor shafts so cheap that if it fell from hip height to the floor, it was ruined.
BTW, CCS is Cheap Chinese Sh- well, you understand.
