Home Racing World • View topic - Bending Brake
Bending Brake
Bending Brake
Postby ddyke » Sat Nov 23, 2013 11:23 am
ddyke
Re: Bending Brake
Postby RazorJon » Sat Nov 23, 2013 12:24 pm
its for thin stuff, I use .062 X .5 for my bulkheads and I do not think this will handle it
have you used it yet?
Re: Bending Brake
Postby waaytoomuchintothis » Sat Nov 23, 2013 1:58 pm
Re: Bending Brake
Postby Ember » Sat Nov 23, 2013 10:07 pm
Happy to see this post here, because I was feeling awfully tempted by it and feeling a little annoyed that I had only just placed an order days before. I feel better now. Thanks.
Re: Bending Brake
Postby RichD » Mon Nov 25, 2013 10:44 am
I bought an 18 inch bending brake from Harbor Freight that should be good for thicker stock. I have not yet had an occasion to use it, but the part that holds the stock in place is not attached to the rest of the brake in any way. I would have to use C-clamps to hold it down. I guess that I should get off of my duff and screw the brake to some plywood. If I was really ambitious I could drill and tap the base to take some 1/4 inch machine screws so I would not have to use C-clamps.
Re: Bending Brake
Postby RichD » Fri Nov 29, 2013 11:30 am
I did get ambitious and screw the brake to a piece of chip board. I drilled and tapped the brake for 1/4 inch hex head machine screws. I made the holes in the clamping part oversized so that I could adjust for different thickness.
Return to SlotCar ToolTime
