Home Racing World • View topic - What is your next tool?
Postby ddyke » Wed Oct 30, 2013 4:23 am
What tool is next on your list?
Mine:
1. Air filtering system.
2. Complete set of small tap and dies in inches and metric.
I want what other people want!
ddyke
Re: What next?
Postby HomeRacingWorld » Wed Oct 30, 2013 6:19 am
1. Paint booth
2. Larger vise
Re: What next?
Postby ddyke » Wed Oct 30, 2013 6:31 am
Those too Harry! What others want I end up wanting. This is why we ask this.
ddyke
Re: What is your next tool?
Postby waaytoomuchintothis » Tue Nov 05, 2013 2:27 pm
Jeremy, its easy to get a match wall wart type of converter and hook it up to your base. Nothing to it, usually.
Postby waaytoomuchintothis » Tue Nov 05, 2013 2:42 pm
The thing that slides has the same exact technology as any other charger. The reason for the individualized chargers is to make the batteries exclusive to a brand. What's inside the charger is just a wall wart of one shape or another. The port for the battery is what makes it a match to that company's battery. You've got two dead ones... break one open and get the specs off the label of the transformer inside. You could replace both of the insides for very little. I have one transformer/wall wart/charger that came with a dial to select voltage, and sixteen plugs to choose from. It matches everything in terms of spec, but you still need the B&W plastic to engage the battery, so save that and the contacts.
Postby HomeRacingWorld » Tue Nov 05, 2013 2:46 pm
Cordless drill? I thought young guys like you still did things the Amish way?
Postby Ember » Tue Nov 05, 2013 2:57 pm
A spray booth would be good.
Postby ddyke » Tue Nov 05, 2013 6:12 pm
I can't paint in the fall or winter as I need a spray booth. My wife has a type of epilepsy and it sets her off.
ddyke
Postby sidedraft » Tue Nov 05, 2013 7:03 pm
1. Tire razor
2. Gear puller
3. Regulated dc power supply (one that works)..
4. New soldier iron, older than dirt the one we use now, been digital chipping too many guys cars.
5. Hope the wife sees this, :lol: hint, hint,, birthday around the corner....
sidedraft
Postby dreinecke » Tue Nov 05, 2013 9:19 pm
Luckily, I won't be as broke as Sidedraft is about to be...
Paint booth
Postby sidedraft » Wed Nov 06, 2013 9:35 pm
sidedraft
Postby waaytoomuchintothis » Wed Nov 06, 2013 11:57 pm
I had to buy a tiny belt sander for the track today. Little booger, operates with one hand. I thought it would be just right for the swelled joints, but after working all afternoon on it, I'm more or less where I was. But I have a nifty little belt sander to put on the shelf!
Return to SlotCar ToolTime
