Milling plastic
Milling plastic
Postby oz10k » Mon Feb 29, 2016 5:58 pm
A while back I got a cheap cross-slide vise on Amazon, and I finally got a chance to use it. I decided I wanted to mount an Artin chassis to a Strombecker body. To do that I had to cut-off the sides of the chassis. I know milling on a drill press is not recommended, but with pretty thin plastic I wasn't too worried about it.
Here are a few in-progress pictures:
I've got a lot more work to do on the project, but I'm happy with the start:
Ron
oz10k
Re: Milling plastic
Postby TuscoTodd » Mon Feb 29, 2016 9:52 pm
That looks like it was a lot nicer way of going about it than using a dremel with a cut off disk or a razor saw!
Thanks for sharing! :)
Re: Milling plastic
Postby Abarth Mike » Tue Mar 01, 2016 1:13 am
Always satisfying when something works out.
Abarth Mike
Return to SlotCar ToolTime
