Home Racing World • View topic - Replacing sandpaper on Tire Razor
Postby edmagner » Tue Jan 05, 2016 8:15 pm
Jon
What's the best way to replace worn out paper on the sanding blocks?
What grade would you use for PG Urethanes?
Sorry if these are answered elsewhere
Thanks
Ed
edmagner
Re: Replacing sandpaper on Tire Razor
Postby HomeRacingWorld » Tue Jan 05, 2016 8:41 pm
I use 1500 to 2000 fine for PG urethanes. You can use double sided Scotch tape if you cannot find or want to buy the larger types.
Postby waaytoomuchintothis » Tue Jan 05, 2016 9:06 pm
I buy self-stick (peel 'em and stick 'em), disks and cut them up to fit.
Postby RazorJon » Tue Jan 05, 2016 11:42 pm
any automotive wet dry sand paper is best, I been using 1500 grit and have had very good results
thin double sided tape, carpet tape and look at a scrapbooking store, they have some good thin double sided tape
hope this helps
Postby dw5555 » Wed Jan 06, 2016 12:55 am
You guys must be at the truer along time. I use 180 drywall screen and more times than not it still takes me at least an hour to cut em even. I always have 1/2 the tire barely touching and the other half cutting away.
In fact I'm doin a set now where only half the tire is sanding. Takes awhile. This is actually the norm for me, very rarely do I put a set on and it sands even.
Dave
dw5555
Postby HomeRacingWorld » Wed Jan 06, 2016 7:22 am
Postby edmagner » Wed Jan 06, 2016 7:52 am
Thanks everybody for the great info..
What grit come's on the Razor originally? - that has worked well for me so far -it's just getting a bit worn.
Ed
edmagner
Postby RazorJon » Wed Jan 06, 2016 9:52 am
Return to SlotCar ToolTime
