How to Care for your Razor
I built the Razor to last a life time and with these simple steps your Razor will last
First is the main screw a drop or 2 of light weight oil on the threads
Turn the screw down so you can oil the bottom of the screw between the axle block and top cap
Your Motor has bushings front and rear
DO NOT OVER OIL YOUR MOTOR
Hope to do more of these tips, tell us what you think, and if you have a tip please share here
