Home Racing World • View topic - How to Care for your Razor
Postby RazorJon » Fri Nov 27, 2015 6:45 am
I built the Razor to last a life time and with these simple steps your Razor will last
First is the main screw a drop or 2 of light weight oil on the threads
Turn the screw down so you can oil the bottom of the screw between the axle block and top cap
Your Motor has bushings front and rear
DO NOT OVER OIL YOUR MOTOR
Hope to do more of these tips, tell us what you think, and if you have a tip please share here
Re: How to Care for your Razor
Postby TuscoTodd » Fri Nov 27, 2015 8:32 am
Great tips for a a VERY handy tool! Thanks Jon! :D
Postby HomeRacingWorld » Fri Nov 27, 2015 8:56 am
I will save all of these in the archives.
Postby dw5555 » Fri Nov 27, 2015 9:34 am
Actually I just had to take mine apart for the 1st time after 2 yrs of hard use. The posts where getting gummed up and not letting it slide easy. So while everything was apart for cleaning I dunked the motor in alcohol bath and cleaned it also. Everything oiled and back together and good as new. :banana-dance:
Dave
dw5555
Postby RazorJon » Mon Nov 30, 2015 12:05 pm
Return to SlotCar ToolTime
