I'm not sure if I've posted photos of it before, but here's the spray booth set up I have. As you can tell by its cleanliness I haven't had time to use it yet. It is summer now here in Australia so when I get back from Sydney around Christmas I will have a go at it, as I have pretty much all I need bar the paints.
Folded:
Open (you can see both the standard turntable and the Tamiya one in this pic:
From another angle:
Seeing as I have two Tamiya turntables I might hot glue this cheap palette to the one that came with the booth (so that the palette doesn't tip and can spin).
The compressor is double-piston Artlogic. The airbrushes are Paasche H and Iwata Eclipse HP-BS.
