Easy way to tin your soldering iron
Re: Easy way to tin your soldering iron
Postby chappy » Wed Sep 16, 2015 6:12 pm
Great tip Dave.
Thanks for posting, very timely for me too.
Postby Audi1 » Wed Sep 16, 2015 6:28 pm
Timely for me, too. Does he wrap the entire tip of the iron with solder and then let it melt on? What diameter solder does he use, 0.15, 0.22............? Does he use any flux in the iron tip before wrapping with the solder (couldn't get that from the start of the video, although it might have been there.........). Thanks.
Postby Gentleman Norb » Wed Sep 16, 2015 7:25 pm
I want that 3 minutes of my life back!
Gentleman Norb
SlotCar Aristocrat
Postby HomeRacingWorld » Wed Sep 16, 2015 7:34 pm
:) Well...I just did it. On my new iron that I have used. Now I have kept it clean by using the copper pad.
Worked great! Even on the larger iron that Doc and I bought at the same time that has been used. Cleaned, wrapped, heat and serve :)
Thanks Dave!
Postby dreinecke » Thu Sep 17, 2015 10:21 am
Good stuff, and that's how I did mine.
Postby Z-carfan » Thu Sep 17, 2015 10:55 am
Great timing for me too, just received my soldering in the mail. Hakko FX888D.
I did some test soldering last night, I am assuming that I can still use this technique even though the iron has been used once?
Postby HomeRacingWorld » Thu Sep 17, 2015 10:56 am
Yep, just clean it beforehand. I did both of mine last night and they were both used a few times.
Postby Z-carfan » Thu Sep 17, 2015 11:13 am
Sounds good, thanks guys. This weekend should be fun now! :)
Return to SlotCar ToolTime
