Home Racing World • View topic - Tire truers
Tire truers
Re: Tire truers
Postby Cosmic Bilby » Fri Nov 30, 2012 7:03 am
Thats Excelllent!
Really brings back some memories.....
I started with the wheel chucked in a dremel (as most did), and used a block of wood with sandpaper stuck to it to get the diameter. It was very tedious but from the tyres I've pulled off old models seemed to be pretty accurate (I used digital verniers as a sort of go/no go gauge, still do now too).
I've moved on a little now, I got an Area 3 truer a couple of years back, its made things quicker, still not perfect though, I would prefer one of Johns little beauties....
Cosmic Bilby
Re: Tire truers
Postby HomeRacingWorld » Fri Nov 30, 2012 7:07 am
Re: Tire truers
Postby Burglar » Fri Nov 30, 2012 7:45 am
That's the one I have (Jon's Tire Razor) and truing machines aren't cheap so I'm not planning to start a collection!
Burglar
Re: Tire truers
Postby ListerStormGT » Fri Nov 30, 2012 11:52 am
Another Tire Razor here... my old standby was a setup block wired to my power supply.
Re: Tire truers
Postby RazorJon » Fri Nov 30, 2012 12:12 pm
Re: Tire truers
Postby boopiejones » Fri Nov 30, 2012 7:11 pm
Two of those pics from post #1 are mine. Now I know what it feels like to be an Internet celebrity!
Ive made some new tire truers since then. Il try to post pics tonight.
boopiejones
Re: Tire truers
Postby FootScoot » Fri Nov 30, 2012 10:01 pm
I have 2. An old Cobra, which I use most often. I bought another one, but have yet to even try using it. :)
Re: Tire truers
Postby boopiejones » Fri Nov 30, 2012 11:30 pm
my real hudy:
travel version of my sander/cleaner pictured in post #1:
this next one isn't really a tire "truer." it is a machine to massage oil into rubber tires:
broken avant slot chassis and worn out slot it motor, converted into a tire sanding gizmo:
boopiejones
Re: Tire truers
Postby buspor63 » Sat Dec 01, 2012 7:55 am
My kids really like the pic of the crew truing tires :lol: Lots of great home shop solutions out there.
My brother and I share a Tire Razor, excellent product !! To me the benefit is being able to true stock plastic wheels in pairs on stock axles.
buspor63
Re: Tire truers
Postby ddyke » Sat Dec 01, 2012 11:20 am
ddyke
Re: Tire truers
Postby olskoolslotz » Sat Dec 01, 2012 8:47 pm
olskoolslotz
"THE Champ"
Re: Tire truers
Postby waaytoomuchintothis » Sat Dec 01, 2012 9:51 pm
Rob- Dan's slick operation is the only competition for the Tire Razor as far as I am concerned. I think he's busy building a new track, so I'll explain it briefly for him.
It works like this: The spindle sander spins the wheels, and the spare drum, held in perfect alignment by the table of the spindle sander is eased into place alongside, truing the tires or wheels very quickly and accurately. I have a Tire Razor, and I use it al the time, but for big jobs when I need to lower a car's profile, I get out the spindle sander and make very short work of it.
Re: Tire truers
Postby ddyke » Sat Dec 01, 2012 10:51 pm
RMinAustralia,
The spindle on the sander spins the tyres/tires. The tire rubs on the larger drum. The chassis rests against the larger drum and the drum (because it is large) is rolled into the tire gently. I may make a video as it is hard to explain but easy to do. The thing has gobs of torque. The larger drum can be Wrapped with fine grit sandpaper to polish a tire. Since I own the sander, it was cheap.
ddyke
Re: Tire truers
Postby HomeRacingWorld » Sun Dec 02, 2012 12:21 pm
Don't forget this old German unit
Re: Tire truers
Postby Cosmic Bilby » Sun Dec 02, 2012 5:10 pm
Das ist gut Ja???
Cosmic Bilby
Return to SlotCar ToolTime
