Home Racing World • View topic - Dremel #114 cutter bit
Postby btaylor » Thu Mar 05, 2015 12:08 pm
This may have been addressed before on here, but i wanted to share this with anyone building resin body cars.
The Dremel round cutter is the fastest, cleanest tool for removing resin from the inside or out side of a slot body.
The listed number for this bit is #114. The cost was around $8.50 at my local ACE hardware store. It cuts very smooth, and leaves hardly any ridges. It is easy to maneuver inside the body as well as thinning around window posts.It also does not produce the dust that some bits do, but more of a Fluffy shaving, almost like wood shavings from a table saw.This is a picture of it, and the link for a better description.
http://www.dremel.com/en-us/Accessories ... px?pid=114
Re: Dremel #114 cutter bit
Postby RazorJon » Thu Mar 05, 2015 12:35 pm
thats one of my favorite bits, I have 2 that are smaller balls, 1\8 and 1\16
Postby turbokev » Thu Mar 05, 2015 12:50 pm
Yep.. I put that bit to good use this morning :D
turbokev
Postby RichD » Thu Mar 05, 2015 2:09 pm
For the inside of resin bodies I like the large diameter sanding drums. I keep the nozzle of a vacuum cleaner close to the work.
Postby HomeRacingWorld » Thu Mar 05, 2015 2:23 pm
The go to bit for me as well Bob. Does just what you describe.
Postby btaylor » Thu Mar 05, 2015 2:34 pm
Postby J Y D » Thu Mar 05, 2015 3:40 pm
Thanks for sharing ... J Y D
J Y D
Return to SlotCar ToolTime
Users browsing this forum: No registered users and 39 guests
