Screw Threads
Screw Threads
Postby ddyke » Sun Mar 01, 2015 1:41 pm
Which thread do the SlotIt grubb screws use: M2x40 or M2x45?
ddyke
Re: Screw Threads
Postby RichD » Mon Mar 02, 2015 8:34 am
I have never seen that information listed. If I had a metric thread gauge I could check on that. Some of the M2 screws out there a rather low quality and the socket will round off very easily, even if you use a torque limiting wrench. If you want high quality screws at a reasonable price try the ones from Slot Car Corner.
Re: Screw Threads
Postby ddyke » Mon Mar 02, 2015 8:51 am
I am not trying to buy screws but the appropriate drill and tap. I should have explained.
ddyke
Re: Screw Threads
Postby Oscar Racing » Mon Mar 02, 2015 11:10 am
The M2.0 x .40 is the tap size, the drill bit you need is 1.6mm or the #53 will work...
The M2.5 x .45 is the tap size, the drill bit you need is 2.05mm or the #47 or #46...
Working with plastic isn't a big deal, if you go to alum or steel be careful, buy split point drill bits
I hope that helps...
Oscar Racing
Re: Screw Threads
Postby ddyke » Mon Mar 02, 2015 11:23 am
It helps but I need to know which works with the SlotIt screws.
Thanks Shotgun for the thread type.
ddyke
Re: Screw Threads
Postby Oscar Racing » Mon Mar 02, 2015 11:50 am
[quote="Oscar Racing"]The M2.0 x .40 is the tap size, the drill bit you need is 1.6mm or the #53 will work...
The M2.0 x 40 is the Slot.it size...
Oscar Racing
Return to SlotCar ToolTime
Users browsing this forum: No registered users and 26 guests
