Home Racing World • View topic - Hay bales
Hay bales
Plastic Or Wood
All Things Track Building!
Hay bales
Postby btaylor » Sat Dec 27, 2014 2:05 pm
Thought I would share these with the scenery folks.
Got these on clearance at wall mart. They are called project blocks by a company called florafoam. they are supposed to be for buildings,and I guess they would make great retaining walls too, But they are perfect scale hay bales for 1/32 tracks.
they come in a beige color,but they paint up well in a hay color. Great for Oval tracks , and vintage road courses. They come 300 to a box, so there are plenty!
Re: Hay bales
Postby BRP32 » Sat Dec 27, 2014 3:22 pm
Great scenery idea!
May have to pick some up and cut them down to Ho scale for my 4 lane oval I'm about to build in Ho.
Thanks for the heads up!
Wayne :text-thankyouyellow:
BRP32
Re: Hay bales
Postby TsgtRet » Sat Dec 27, 2014 4:16 pm
Shotgun I'm going to have to get a box of these and intermix them with resin ones......a little variety never hurt!
Thanks Bob!
Re: Hay bales
Postby dreinecke » Sat Dec 27, 2014 4:26 pm
Wow! Those look perfect! I'm going there as soon as I get home! Thanks for the tip!
Re: Hay bales
Postby dge467 » Sat Dec 27, 2014 5:30 pm
Cool find! I am still getting my free ones off of new Lincolns at work though!
Re: Hay bales
Postby btaylor » Sat Dec 27, 2014 6:10 pm
Jeff, the ones you are using are great, I would not change over to these. I have so many different versions of hay bales, I have no continuity in size or shape. I must admit that these foam blocks look about as close as you can get to a bale of hay,and they are all the same. very light, and stiff. and easy to paint. I looked them up on line,and they run about $20 when not on clearance. I guess that's not to bad for three hundred of them!
Re: Hay bales
Postby dge467 » Sat Dec 27, 2014 6:29 pm
That is a good find Bob! I got plenty more of the one's I get from work if you may need more.
Re: Hay bales
Postby slothead » Sun Dec 28, 2014 1:01 am
Are you folks actually finding these in your local Walmarts, or having to buy online and pickup at the store? I can't tell if either of the nearby stores have these in stock or not.
Slothead
Re: Hay bales
Postby scatman » Sun Dec 28, 2014 7:39 am
scatman
Re: Hay bales
Postby bookie » Sun Dec 28, 2014 8:51 am
bookie
