Home Racing World • View topic - Bad at soldering....
PostPosted: Mon May 26, 2014 5:11 pm
by bobbyraz49
My 1st routed track works, but.... I am new at soldering the wires to the tape and I don't like the looks or the slight bump .
So...I am thinking of drilling a hole and feeding copper tape to the underside , placing a washer against bottom of MDF, then placing a wire clip and a bolt to hold in place.
Thoughs ?
Suggestions ?
And, begin !
Re: Bad at soldering....
PostPosted: Mon May 26, 2014 5:42 pm
by Nor Cal Mike
Like Harry said the saddle tie is my favorite for copper tape.
PostPosted: Mon May 26, 2014 7:07 pm
by bobbyraz49
PostPosted: Mon May 26, 2014 10:02 pm
by dreinecke
That's exactly how I did mine:
PostPosted: Tue May 27, 2014 9:53 am
by Wolseley Hornet
I've used this method too. It works just fine with or without the tape over the top.
David.
PostPosted: Tue May 27, 2014 10:16 am
by bobbyraz49
Thanks folks !
PostPosted: Tue May 27, 2014 3:59 pm
by Florida_Slotter
There are many different ways to connect the power. Whatever one works for you is what you should use. I like Doc's photos as they look like they work very well. Soldering 14 gauge wire to thin copper tape is NOT an easy thing to do.
As they say, there are more than one way to skin a cat. Unfortunately for the cats, we keep coming up with so many different ways.
PostPosted: Tue May 27, 2014 4:29 pm
by Ember
The hill climb here is done with screws through the track. HL just put short strips of copper tape on the track where the screws went first before applying tape over the whole lot. On the underside the power wires are soldered straight to the brass screws. Much more simple than the bizarre plan that His Lordship was going to use.
PostPosted: Wed May 28, 2014 6:34 am
by bobbyraz49
The sunken bolt through the MDF worked great ! TY
PostPosted: Fri May 30, 2014 6:17 am
by bobbyraz49
