Home Racing World • View topic - Bad at soldering....
Got Wood?
Your ROUTED TRACK Home!
Postby bobbyraz49 » Mon May 26, 2014 5:11 pm
My 1st routed track works, but.... I am new at soldering the wires to the tape and I don't like the looks or the slight bump .
So...I am thinking of drilling a hole and feeding copper tape to the underside , placing a washer against bottom of MDF, then placing a wire clip and a bolt to hold in place.
Thoughs ?
Suggestions ?
And, begin !
bobbyraz49
Re: Bad at soldering....
Postby Nor Cal Mike » Mon May 26, 2014 5:42 pm
Like Harry said the saddle tie is my favorite for copper tape.
Postby bobbyraz49 » Mon May 26, 2014 7:07 pm
bobbyraz49
Postby dreinecke » Mon May 26, 2014 10:02 pm
That's exactly how I did mine:
Postby Wolseley Hornet » Tue May 27, 2014 9:53 am
I've used this method too. It works just fine with or without the tape over the top.
David.
Wolseley Hornet
Postby bobbyraz49 » Tue May 27, 2014 10:16 am
Thanks folks !
bobbyraz49
Postby Florida_Slotter » Tue May 27, 2014 3:59 pm
There are many different ways to connect the power. Whatever one works for you is what you should use. I like Doc's photos as they look like they work very well. Soldering 14 gauge wire to thin copper tape is NOT an easy thing to do.
As they say, there are more than one way to skin a cat. Unfortunately for the cats, we keep coming up with so many different ways.
Postby Ember » Tue May 27, 2014 4:29 pm
The hill climb here is done with screws through the track. HL just put short strips of copper tape on the track where the screws went first before applying tape over the whole lot. On the underside the power wires are soldered straight to the brass screws. Much more simple than the bizarre plan that His Lordship was going to use.
Postby bobbyraz49 » Wed May 28, 2014 6:34 am
The sunken bolt through the MDF worked great ! TY
bobbyraz49
Postby bobbyraz49 » Fri May 30, 2014 6:17 am
bobbyraz49
Return to The Lumber Yard
