Need to figure out what to do about lap timing and race management now that I'm starting to braid..
I went to the trakmate site to check out software as that is what I've used in the past.. and read that
if I do dead strip timing, it only works in one direction? I can't reverse the layout.. Which I want to be able to do.
I really don't want an overhead light bridge and LED sennsors.. I think dead strips are more reliable.. not that I've
ever had them on one of my tracks, but other tracks I've raced at with dead strips always work flawlessly with
no super bright light bridge being a distraction..
Is it possible to have 2 dead strip locations and toggle back and forth depending on which direction I'm running the track?
Any solutions you guys might have would be appreciated.. and software / interface suggestions as well.. I've always used
TrakMate in the past and thats what most use up here.. but I'm open if it does the same things TM does..
Thanks!
