testing, testing...
Got Wood?
Your ROUTED TRACK Home!
testing, testing...
Postby bkrownd » Sat Feb 15, 2014 3:03 pm
For proxy development I need a test loop appropriate to that task. I had to buy the router and appropriate bits of hardware and woodware. ($$$)
I'm thinking to embed bits of Ninco track into the edge so I can expand that way if desired, and just stick a rally loop on that if I don't.
need to search for foil now...
bkrownd
Re: testing, testing...
Postby dreinecke » Sat Feb 15, 2014 9:51 pm
Are you going to seal both sides of the wood? I recall another member years ago in HI that had issues with the wood swelling up?
Either way, glad you are building one!
Postby bkrownd » Sun Feb 16, 2014 1:18 am
Yes, paint. It isn't among the more vulnerable things we own. I lose much more valuable stuff to the humidity and fungus every year, but we aren't in a really bad area. MDF will sag without an extensive backing structure, though.
bkrownd
Postby bkrownd » Sun Feb 16, 2014 4:38 pm
I should have 3 4x6 panels built by this evening and can start drawing on them. Now, where did I put that giant "french curve"?
I also need to look into paint. I was wondering if green felt or "velvet" might be fun for "grass", or just a PITA?
I'm wondering if this thing might be able to do double duty as a giant gaming table, for the Dungeons & Dragons events, the sailing ship battles, and such. Each panel is larger than any table we currently have. I'm wishing we didn't buy that fancy mango wood table the cats have claimed as a jungle gym and catfight arena.
bkrownd
Postby dreinecke » Sun Feb 16, 2014 10:04 pm
Catfight arena? I'll bet you could make money on Pay-per-View...
I'd do some felt for the grass - that should work pretty well I'd think. Would also work for your marathon D&D events.
Postby bkrownd » Mon Feb 17, 2014 2:36 pm
I need to think about a way to align the panels when assembling everything. It could be challenging to get a level surface along the 2 edges where panels meet every time they're put together. I should make sure the slot only crosses each edge in 2 places to make that easier to align.
bkrownd
Postby WB2 » Mon Feb 17, 2014 4:21 pm
Mold makers' alignment pins would be the cat's meow for keeping surfaces aligned. Wood pins wear after a while or swell from moisture.
See: http://www.009.cd2.com/members/how_to/alignment.htm .
Poor man's way: http://railwaybobsmodulebuildingtips.bl ... bolts.html .
WB2
Postby bkrownd » Mon Feb 17, 2014 4:45 pm
Thanks for the links
bkrownd
Postby bkrownd » Sat Feb 22, 2014 11:08 pm
I started drawing something freehand but then switched to CAD, and after some noodling I have the following possible layout for the first 4x6 panel
The straight along the bottom edge runs along all 3 panels, with the big curve at each end. This panel has a variety of curves, with a minimum slot radius of 4 inches. The middle 4x6 panel will have more of a large simple S shape, and I haven't decided on what to put in the last 4x6 panel yet.
My copper tape arrived, but I still need paint.
bkrownd
Postby bkrownd » Mon Feb 24, 2014 3:19 pm
I've (unintentionally) spent the entire weekend on design and layout. I was going to cut in sections, but after laying out and aligning the first part of the routing guide fence I decided it would be much smoother if I did the entire panel at once even though it's consuming my entire weekend. The plastic strip I'm using can just (barely) do the 4" slot radius hairpins smoothly. (5.75 inch guide fence radius) Lots of nails.
I'm trying to decide what depth I should set the slot at - 7, 8 or 9mm? I was expecting to do 7mm, but after more looking around the interwebs I'm seeing 9-10mm suggested, which seems a lot in 12.5mm thick material. I may need to add more backstructure
bkrownd
Postby bkrownd » Sat Mar 01, 2014 6:35 pm
I didn't make any progress during the work week. As I get back to it I feel the need to make faster progress. As much as CAD helped design the tight sections smoothly, it was tedious to lay out - placing all the centers and marking all the curves - so I decided to freehand the rest of this panel, and entirely freehand the less compact configuration of the middle panel.
bkrownd
Postby bkrownd » Sun Mar 02, 2014 4:46 pm
Panels 2 and 3 laid out
All 3 together for the first time: (the router will run on the inside of the guide pattern, where the cars are for scale)
bkrownd
Postby dreinecke » Sun Mar 02, 2014 10:46 pm
Really looks like you're getting there! So, you're routing it all at once?
BTW - your track manager says get back to work and stop posting pictures...
Postby bkrownd » Mon Mar 03, 2014 1:57 pm
Hopefully today. A plumbing disaster set me back a couple of hours.
I'll have to do this on the patio. Router says only 1/8" depth per pass, so it will take 2 passes. I may start using the second bit halfway through.
bkrownd
Postby bkrownd » Mon Mar 03, 2014 4:32 pm
LOL - the router spec is 20,000-30,000 RPM. The speed control dial on the front is numbered 1-7. ....um...OK...
Unfortunately the fine print on the bits I have says max RPM 24,000, and the fine print on the router says "never use bits rated less than 30,000 RPM"
went out and bought new bit....
bkrownd
Return to The Lumber Yard
