Suggestions please.
Got Wood?
Your ROUTED TRACK Home!
Suggestions please.
Postby waaytoomuchintothis » Wed Nov 27, 2013 5:19 pm
I need a slightly flexible catch wall material to around a track that is higher off the ground than most. Its 8 x 16 feet, and the catch wall will go around the outside of the rectangle, rather than following the track path. I was thinking about a rubber baseboard material that comes in big rolls for use in office buildings and schools, then I found out how much that stuff costs. That's out. I can't think of another building material like it. If I build it from wood, it will be uncomfortable to reach over. The best I can do in that situation is to round the top of the wall. Any ideas?
Re: Suggestions please.
Postby HomeRacingWorld » Wed Nov 27, 2013 5:39 pm
How tall an edge?
Postby waaytoomuchintothis » Wed Nov 27, 2013 6:34 pm
I think that stuff may be too flexible without something to stake it up, Dave. I'll go look at it.
Harry, I only need about 4 inches or less. I can make a wood wall and top it with a flexible material, I think, but all I really want to be sure cars won't make a 4 foot drop to concrete, but still not bruise the guys reaching over it. Maybe I should just round over the wall and make it out of soft pine, painted to look like concrete on the inside and a color on the outside. When the scenery is added, the wall should look like a seawall or a Corps of Engineers levee breach gate.
Postby HomeRacingWorld » Wed Nov 27, 2013 6:48 pm
Well....why not good old plastic gutter guard?
Cheap, flexible, and easy to reach over.
Postby waaytoomuchintothis » Wed Nov 27, 2013 11:35 pm
The trouble there is that the posts to hold it up would be like spikes for the guy leaning over. Remember this track is higher off the ground than most.
Postby ListerStormGT » Thu Nov 28, 2013 3:05 am
Rob, couldn't you just use a staple gun to attach the gutter guard around the table and you wouldnt need posts? Its rigid enough to stand on its own if it was attached that way.
Postby Junior » Fri Nov 29, 2013 3:29 pm
If you want to go really cheap, use vinyl siding, you can get a 12' piece for under $4. If you cut it into strips, you can get about a 3.5" wide. It isn't the easiest to cut, you will need shears. Another option is vinyl soffit, it is 8" but is about $12 for 10'.
All the white border on my test track is vinyl siding.
Tom
Junior
Shop Teacher
Postby waaytoomuchintothis » Fri Nov 29, 2013 3:52 pm
Tom, that's it! Perfect. And I have loads of it left from doing the house and outbuildings a few years ago. Excellent!
By the way, its best to cut that stuff with a sharp plywood blade turned around backwards on a table saw or circular saw.
Return to The Lumber Yard
