Home Racing World • View topic - My new track
My new track
Got Wood?
Your ROUTED TRACK Home!
My new track
Postby chappyman66 » Fri Jul 05, 2013 11:57 pm
My first routed track got taped and tested today. Thanks to Dave R, Old Jaybird, Bibbster, and all of the helpful folks here.
It won't get much scenery, but it should be something to run on until I can build a permanent track.
Re: My new track
Postby Dangermouse » Sat Jul 06, 2013 6:39 am
That will be a good fun drive.
cheers
David
Dangermouse
Re: My new track
Postby dreinecke » Sat Jul 06, 2013 7:12 am
That is awesome! And a big track to boot! Looks like it will have a nice flow to it.
Re: My new track
Postby chappyman66 » Sat Jul 06, 2013 8:04 am
Thanks for the kind words. You can see the edges are rough, etc. Not a real finished product, but since I was fortunate enough to have the tools and a wife who told me I should be able to "play with my cars" I figured I should make it happen. I wanted three lanes, so a pair of 4x8 sheets was almost required. Since it was $5 per sheet I didn't feel badly about it...there isn't much investment other than the time.
Gotta get power and driver stations wired now.
Re: My new track
Postby ourwayband » Sat Jul 06, 2013 8:16 pm
Great looking track.Now that one will be fun to run on!
Re: My new track
Postby HomeRacingWorld » Sat Jul 06, 2013 8:44 pm
Nice job indeed. Looks like a fun course.
Re: My new track
Postby chappyman66 » Sat Jul 06, 2013 9:35 pm
Thanks everyone for the kind words.
I got the particle board at Menards (local big box building supply store). They were in the close-out bin because corners and edges had been damaged. I just routed to avoid those, and one place got filled with Bondo during the smoothing stage. The tape (inexpensive as it was) was more than the wood, so I just did what looked reasonable.
It's made to be "portable" and storable. I can lay it sideways against the garage wall when it's not in use. I would like to get a couple sets of folding table legs to screw underneath so it's up off the floor, but this works for now. It's a small track but the lanes should be a good match for racing. The middle is clearly the fastest (as expected) but each gutter has some sharp corners so hopefully they will even out.
I got it all wired up and running tonight after dinner. My sons (17, 15, 13) were playing a game in the basement and I called them out to see....after several iterations of "we should go back to the game" the laps were still being run. Several moths and mosquitos became road kill. :lol: It's too hot in the garage to be out there long tonight, but it got a reasonable initiation considering I didn't clean it and just gave them Artin Lola prototypes to play with. Tires not sanded or anything, so hopefully the good cars will run better. I will try cleaning it and running some good cars tomorrow ;)
Re: My new track
Postby chappyman66 » Sat Aug 17, 2013 10:46 pm
Re: My new track
Postby KsRacer » Sun Aug 18, 2013 8:07 am
Chappy that is a nice job on your first routing job, it looks like it flows pretty good, and will get faster once it rubbers in. I have run on a couple home tracks in our area and they got faster as we run on it.
Dave K.
KsRacer
Re: My new track
Postby chappyman66 » Sun Aug 18, 2013 9:15 am
Well, it's my first routed home track. But it's not the first track I routed...I helped build a commercial tri-oval (8 lanes, 28 degree banking) several years ago so I sorta had a head start. ;)
Still, it turned out OK for a temporary garage circuit. The corner at the near end is decreasing radius so it's trickier than it looks, and by putting a kink in each gutter lane I think I evened it out pretty well so the lanes will drive pretty evenly.
Now I need timing and scoring so I can have some reliable tuning results. :D
Re: My new track
Postby KsRacer » Mon Aug 19, 2013 1:26 pm
I see a train transformer for power, what kind is it and what is the power rating.
Thanks, Dave K.
KsRacer
Re: My new track
Postby HomeRacingWorld » Mon Aug 19, 2013 1:29 pm
Nice work. That will be a great course.
Re: My new track
Postby chappyman66 » Mon Aug 19, 2013 3:48 pm
It's powered off a standard battery charger. I have a good power supply in the basement but the charger works fine and lives in the garage anyway. The good supply is for the nice permanent track when my older son moves out to college next year ;)
Return to The Lumber Yard
