Page 1 of 2
New track in central Illinois
Sun Jul 03, 2016 1:48 pm
by marriott211
Okay, I picked this up from bookie a couple weeks back. Got it laid out but for the life of me I can't figure out how to elevate the sections I need. Anyone have experience with these tracks?
Jim
Sent from my SM-N910V using Tapatalk
Re: New track in central Illinois
Sun Jul 03, 2016 6:14 pm
by mattb
Easy way is a table saw to cut various height pieces of 1 X 4 pine and a glue gun to stick them to the table and track. If you can't do that, styrofoam blocks cut with a knife and a glue gun will work. You will need to connect the overpass to both adjacent pieces before you start to worry about the elevation.
Just my opinion, but to make the track flow good I would loose that curly que that leads under the overpass. Looks like the pieces you have can adjust to that change.
Sun Jul 03, 2016 6:22 pm
by marriott211
Thanks Matt. I spent the afternoon working on it and have a good idea on how to put it all together. I like the idea of foam blocks. I've got some left over polystyrene foam sheet in the garage....
Sun Jul 03, 2016 8:30 pm
by WB2
Before you do anything, you need to join the track sections together. You'll get a much smoother transition between levels.
Mind if I ask where you are in central Illinois?
Sun Jul 03, 2016 8:38 pm
by marriott211
Champaign area. What's the best way to join the sections?
Mon Jul 04, 2016 9:10 am
by bookie
The layout is coming along great. I love to see it being put to use :music-rockout:
Mon Jul 04, 2016 9:45 am
by bookie
Since you have section connections and stuff all figured out, I thought I would redo my post so others don't get bored or confused as I tend to go overboard. Just keep the pics coming
Mon Jul 04, 2016 7:00 pm
by marriott211
Mon Jul 04, 2016 8:22 pm
by bookie
I believe in Columbus you said it would be a couple months before you would be able to start. It is looking good :music-rockout: I would be careful on securing the overpass, you have to braid beneath it.
Mon Jul 04, 2016 8:24 pm
by marriott211
Fri Jul 15, 2016 10:41 am
by indybob009
Where are your controller stations going. I assume their against the outer walls. Standing inside the L wont work. Nice looking track also. Should be fun.
Sat Jul 16, 2016 7:28 pm
by marriott211
Tue Jul 19, 2016 10:40 pm
by dreinecke
Great looking track going here!
Wed Jul 20, 2016 7:06 am
by marriott211
Sun Nov 13, 2016 10:23 am
by marriott211
