Home Racing World • View topic - Bank turn
Bank turn
Got Wood?
Your ROUTED TRACK Home!
Bank turn
Postby woodman » Thu Feb 04, 2016 12:44 pm
A demonstration of how I built self supporting bank turns 20 years ago.......The surface was 1/2" partical board the wood strips from 3/4 plywood ripped into 1 1/2" strips, and 1/4" plywood for the backer sheet......it holds its shape before the sidewalls are applied. .....
The model is made from 1/4 ply but the concept is the same.....
On the full size piece I used a ratchet strap to bow the turn.....
woodman
Re: Bank turn
Postby Z-carfan » Thu Feb 04, 2016 1:54 pm
Isn't that hard to route once bent? Looks like a really cool idea.
Re: Bank turn
Postby woodman » Thu Feb 04, 2016 3:26 pm
I routed the track beforehand but it could be done afterwards with no problem......
woodman
Re: Bank turn
Postby RichD » Mon Feb 08, 2016 8:15 am
It is easier to route the turn before you bend it, but bending the turn will close up the slots a little.
Return to The Lumber Yard
