Home Racing World • View topic - Voltage Drop
Voltage Drop
Got Wood?
Your ROUTED TRACK Home!
Voltage Drop
Postby Minnesota Speed2 » Fri Dec 07, 2012 7:21 am
Hi Everyone.
I routed and copper taped a three lane track. This is my first try at it so the tape broke two times on a lane. I patched the break by putting another piece of tape over the broken section and using the knife tip to tap through to the tape below. My middle lane, which I did last has no breaks. All cars have more punch and are faster in the middle lane. Power taps have been included around track after the broken sections. Can you think of something that I did wrong or have any hints
Thanks Chris
Minnesota Speed2
Re: Voltage Drop
Postby HomeRacingWorld » Fri Dec 07, 2012 7:26 am
My first step would be to take the time to solder those breaks. Easy to do.
Re: Voltage Drop
Postby Scatman1 » Fri Dec 07, 2012 7:35 am
I agree with Harry. The way you did it works, but it's a temp. fix.
Scatman1
Re: Voltage Drop
Postby ChallengerGuy » Fri Dec 07, 2012 10:44 am
ChallengerGuy
Re: Voltage Drop
Postby RichD » Fri Dec 07, 2012 11:13 am
If a lane has less power then there must be a break in the tape someplace. Hairline cracks in the tape can be hard to find. Chances are that you put tension on the tape as you put it down that that can cause it to crack later on. Another way to fix the cracks is with conductive silver ink. Radio Shack has conductive ink pens from time to time and they can be found on Amazon as well, but they are overpriced.
Re: Voltage Drop
Postby Minnesota Speed2 » Fri Dec 07, 2012 7:20 pm
I will try to fix it this week end. Is there a best method to sodder?
Minnesota Speed2
Return to The Lumber Yard
Users browsing this forum: No registered users and 35 guests
