Home Racing World • View topic - New track build in Texas
Got Wood?
Your ROUTED TRACK Home!
Re: New track build in Texas
Postby dreinecke » Thu Feb 19, 2015 10:29 pm
WOW! Looks great so far and you've made it look easy! I like the canyon idea myself.
Postby Jabbatee » Sat Feb 21, 2015 12:40 am
Started work on the flyovers...
I cut out a cardboard template that spanned the distance between ends then used it to cut the MDF that fit in that space. Doing so allowed me to draw out the lanes on the MDF in preparation for the routing.
Not sure if that was the best way to do it but is seemed to work for me. Here is another flyover...
At this point, all of the track is connected and is secured to the framework below...
No it is time for some filling and sanding...
Jabbatee
Postby J Y D » Sat Feb 21, 2015 8:19 am
That is turning out really nice.
Should be a blast to drive ... J Y D
J Y D
Postby bobbyraz49 » Sat Feb 21, 2015 8:43 am
Sweet !!!!
bobbyraz49
Postby Gentleman Norb » Sat Feb 21, 2015 8:49 am
Fantastic. I like it!
Gentleman Norb
SlotCar Aristocrat
Postby pfuetze » Sat Feb 21, 2015 8:54 am
Really nice work on a great layout!
Postby indybob007 » Sat Feb 21, 2015 9:07 am
Looking real good. Some tight turns' should make for some good racing. What color are you painting the track. Thanks Indybob
indybob007
Postby Jabbatee » Sun Feb 22, 2015 10:01 pm
Jabbatee
Starting on barriers...
Postby Jabbatee » Tue Feb 24, 2015 5:26 pm
Before I start on painting the track I thought it might be a good idea to start work on the barriers. Here is what I have done so far. Started with gluing blocks of wood on to the underside of the track so the MDF bender board I am using would have something to screw into.
For the corners that are too tight for the bender board, I am using some vinyl trim that I found at Lowe's. Only tricky thing about screwing these into the side of the 3/8 MDF is that you have to find the center of the MDF with the screw...
Jabbatee
Postby SLOTTING SINCE 1963 » Wed Feb 25, 2015 9:28 am
Great looking track.One gets a lot more track length with 2 lanes.
Richard
SLOTTING SINCE 1963
Progress update...
Postby Jabbatee » Sat Feb 28, 2015 7:30 pm
Finished the work on most of the barriers....the driver's stations will be off to the left
Built a little stand (on the left) where the monitor will sit...
Put two coats of primer in the slots...
Two coats of primer on the track...
Got the slots painted...
Hopefully I will get the track painted in the next few days...
Jabbatee
Postby dreinecke » Sat Feb 28, 2015 10:46 pm
Looking good! Man have you been busy!
Postby TuscoTodd » Sun Mar 01, 2015 8:14 am
WOW! That is coming together nice and looks like it is going to be a LOT of fun to race on!
:handgestures-thumbup:
Postby miuraman » Mon Mar 02, 2015 2:44 pm
Hey! Really nice layout! TWO overpasses! One was enough for me! :) But they look good! I used the same type of plastic moldings for the barriers. They work good, but it can be a challenge to find the middle of the MDF, like you said. Short screws are the ticket... ;)
Looking forward to more pictures. Great job so far!
miuraman
Postby bobbyraz49 » Mon Mar 02, 2015 4:04 pm
Will you being using copper tape ?
I am jealous.
Just stunning. Your effort is seen and acknowledged !!!!!
bobbyraz49
Return to The Lumber Yard
