by demether » Tue Feb 04, 2014 9:43 am
I changed my mind. Making my maths, price should be the same between plastic and wood. Maybe even more expensive for plastic.
The track support work will be the same for the 2 projects, even if I will have to add an extra cost on the plastic track for the wood sheets wich will support the plastic layout.
Concerning building work amount, since I want to paint my track, plastic track seems to be where the work will be the more important : clean the track, find dead spot, create borders, central U shaped junction, fix everything, make the electrical taps, etc...
On the wood track I will "just" have to make the slots and apply the copper tape. The track support will be also the track itself, and the track borders.
I will also have more flexibility to make the design I want (like the ones I presented in the last posts). Plastic is not as versatile.
I will continue my research. For example, I'm currently searching info on the router work itself, slot depth and widht, etc...
