Home Racing World • View topic - All American Raceway...Update 7/21
Got Wood?
Your ROUTED TRACK Home!
Re: New track started
Postby ListerStormGT » Thu Sep 12, 2013 10:47 pm
Today I was able to get the track cut out and Thanks to harry for sending me a piece of taped braid I got the gains routed out also. Again thanks to Harry for letting me borrow his bit, that router bit is best thing since sliced bread! After that I was able to get my elevations all set and although it doesn't show, one of the corners turned out to be a nice corkscrew type corner. I got all the screw holes filled in and sanded too. I have to work all weekend but I hope to get the paint done Mon-Tues.
Postby dreinecke » Fri Sep 13, 2013 6:07 am
Looks great, Lee! Really nice work there!
Postby HomeRacingWorld » Fri Sep 13, 2013 7:56 am
Yes indeed, looks good and you are quiet welcome.
David, what a tasteless photo. hehe get it?
Thank you, thank you...I'll be here all week. Try the veal, it's fantastic.
Postby ListerStormGT » Mon Sep 16, 2013 8:25 pm
Got the track painted tonight and going to do the asphalt look again. I will do a step by step with pics as I am doing it tomorrow and post it so if anyone is interested how to do it.
This is the paint I always use on my tracks, but it works as a great base for look I am going for since its a flat paint.
Postby HomeRacingWorld » Tue Sep 17, 2013 10:05 pm
Looking good, very nice!
I want to see this come to life...so get busy :)
Remember the huge salary you get from being a HRW contributing editor.
Postby ListerStormGT » Tue Sep 17, 2013 10:58 pm
Ok I got the surface weathering done today as planned. I think it may have come out a little darker than last time but I am happy with how it looks. All I have left to do is the braid and wire it up and I am ready to run some laps. I thought about painting the slots different colors but I think I like it better just as it is.
Here is what the surface looks like up close with some cars on it.
So here is how I do the weathering after the track is painted in flat grey. I think the flat grey paint as a base is what makes this work the best.
First you need to get a couple cheap spray bottles, I got these at WalMart in beaty section where they have the travel sized stuff.
Then I got the Apple Barrel Acrylic paints in white and black. The cotton terry towels I picked up in the automotive section.
Mix the black and white paints with water to the consistency of milk in each of the spray bottles. Adjust the sprayer nozzle to the finest mist you can get out of it.
It doesn't have to be perfect because you will be blotting the spray with the towel anyway.
I start with the black paint first and spray a small section at a time, then I just use the towel and blot the sprayed area. I may do this a couple times to get the darkness I want.
I also sometimes will spray a small section of black and then white on top of it and just blot it altogether. I use the same towel for both colors as it all works in together anyway.
Here is the finished result.
If something seems to dark or too light you can use the white or black to lighten/darken it up, just spray some over these areas and blot it with the towel. Something else I do that works well for spot touch ups is to spray the color directly on the towel then blot the color on that way. Basically what the black and white paint is doing is its just staining the flat grey base so even though it looks like it has a raised texture, there is no raised texture at all. I think it gives a good effect of making it look like asphalt and its a cheap easy way of doing it.
If you have any questions about this feel free to ask me as I would be glad to help.
Postby HomeRacingWorld » Wed Sep 18, 2013 5:44 am
Nice, looks good. The shade seems pretty good to me.
Good tutorial too, thanks sir. It's a keeper.
Postby HRWJim » Wed Sep 18, 2013 5:41 pm
Looks great man, I like the look being a bit darker. Keep the progress picks coming. Jim
Postby dreinecke » Wed Sep 18, 2013 5:52 pm
Looks good, but...did you forget to route the pit area?
Postby ListerStormGT » Thu Sep 19, 2013 5:47 am
Postby ListerStormGT » Sun Sep 22, 2013 8:37 pm
Having a 3 day weekend I thought I would try to start on a pit area for the track. So fumbling around with tape and paint the last 2 days this is what I have got done so far. Still have a lot left to do but its a start. The green stripes are tape that I I am using for a line to mask from. The pit walls still need trimmed and painted but still getting ideas. Also got one corner of rumble strips painted and like on the last track, the cars will drive over them on the inside lane.
Postby baford1 » Sun Sep 22, 2013 9:14 pm
Lee your track is really starting to take shape like the pit area so far & the rumble strips look good to , are you going to build a pit building ?
Richard
baford1
Postby RazorJon » Sun Sep 22, 2013 10:47 pm
Wow Lee
Thats nice
:banana-rock: :banana-rock:
Postby HomeRacingWorld » Mon Sep 23, 2013 10:04 am
Oh yeah, looks great to me.
Every time I see those Camaros, I want to stop working and race :)
Postby ListerStormGT » Mon Sep 23, 2013 1:46 pm
Thanks guys, glad you like it! :)
Return to The Lumber Yard
