by waaytoomuchintothis » Sun Aug 25, 2013 12:21 pm
There is a 3 inch radius circle on a tire testing rig I built, and it laid that perfectly. No matter what, small kinks are okay, but a stretch of any kind, anywhere is death. It will bug you and foul up forever. Also, the vital stage of burnishing the copper does more for the looks and stability of the track than anything. I generally use and old guide mounted in a small board, and put my weight on it. I just scoot around and burnish one lane, both sides, all at once.
Another thing I did different... By using polypropylene, I planned to use superglue to lock the guide pins in place. When I tested it, I found that the machine lays curves much better if the guides are allowed to rotate in place, the way the trucks at each end of a railroad car operate on curves. But it is critical that the pins should be positioned just right. Maybe I'll take a picture of mine to post later today. Its better to see what I'm talking about.
