The base is in place
Got Wood?
Your ROUTED TRACK Home!
Re: The base is in place
Postby ddyke » Sun Nov 25, 2012 7:37 pm
Not enough space in the infield for the pillar.
ddyke
Postby waaytoomuchintothis » Sun Nov 25, 2012 11:08 pm
How about a routed section that turns the L just before it gets to the pillar?
Postby ddyke » Mon Nov 26, 2012 6:38 am
I found another base and will extend the track enough to miss the pole. I was looking where to pput a filimg cabinet and said, "Dan you stupid fool! Take the base that is by the desk and put it at the end of the track and put the short filing cabinet there!" The track just got longer
ddyke
Postby waaytoomuchintothis » Mon Nov 26, 2012 9:14 am
Always a good sign.
Postby ddyke » Mon Nov 26, 2012 2:01 pm
I put the new base on the end and the wife did NOT notice -another positive sign!
ddyke
Postby waaytoomuchintothis » Mon Nov 26, 2012 2:20 pm
Channel clear. Full speed ahead, helmsman.
Postby ddyke » Wed Nov 28, 2012 10:39 am
The yellow section is set in stone but the white is not.
Alternate #1:
The entry exit points are set in stone as well.
ddyke
Postby waaytoomuchintothis » Wed Nov 28, 2012 4:58 pm
From the end of the decreasing radius left turn at the top of the drawing, right where you sketched in the route, you could put in a a constant radius sweeper, with a little kick into the exit points. It would be just shy of 6 feet long, and would come almost over to the lanes traveling in the opposite direction, so a clear plexiglass catch wall might be needed. On my track, I have thought about a wall to separate, but it never seems like its needed.
Here's what I mean:
Postby ddyke » Mon Dec 03, 2012 7:47 am
PZOOC has drawn some of the suggestions on his CAD program. The third one is interesting.
ddyke
Postby HomeRacingWorld » Mon Dec 03, 2012 8:02 am
Not that it matters, but the last diagram has a very close design to one section of my track. You would not think that increase in radius for that inside lane matters...but it does. Of course, we are just fun running and not doing official racing like your club where you would use lane rotation. But for keeping things close, that increase makes a difference.
Postby ddyke » Mon Dec 03, 2012 9:07 am
Thank you Harry. I am making a further change to the inside. It is not distance but lap times that will matter.
ddyke
Return to The Lumber Yard
