Home Racing World • View topic - Pattos decals answered
Custom Paint Job Showcase
Postby Cincyslots » Thu Oct 25, 2012 11:15 am
This thread kind goes with the Future/Pledge thread.
After my recent paint job I had to find out why Pattos decals wrinkle.. His reply was simple. Only use Future over his decals as stated on his page. It's there, I just never paid any attention to it. The decals do not respond well to the classic spray clear coat. I'm not crazy about Future and never have been. That said. I will give it another go on my next project.
Bruce
Cincyslots
Re: Pattos decals answered
Postby Florida_Slotter » Thu Oct 25, 2012 11:27 am
Bruce,
Sometimes I use just a very light coat of clear and the decals do not wrinkle. Do this once or twice before putting on a heavy coat to seal everything in.
However I also use MicroScale Micro Set and Micro Set to help the decals set into the paint. You can pick that up from a model railroad hobby shop.
Postby waaytoomuchintothis » Thu Oct 25, 2012 12:35 pm
Kinda strange. I have never had Future wrinkle anything at all, whether I airbrushed it on, painted it on with a brush or anything else. The only way I haven't used it is dipping, which is just a waste of Future.
Also weird, Future is acrylic, so what is the difference between Krylon acrylic and Future, other than the propellant?
Postby Cincyslots » Thu Oct 25, 2012 12:43 pm
Rob,
The Future didn't wrinkle the decals. The spray clear coat did.
Bruce
Cincyslots
Postby waaytoomuchintothis » Thu Oct 25, 2012 1:24 pm
Oh well. I'm easily confused. Ask anybody.
Postby Dangermouse » Thu Oct 25, 2012 2:57 pm
I have used an acrylic spray with out problems - Tamiya TS-13 can get a bit hot for the decals. I had the situation where I sprayed two light coast of TS-13 on a car and everything was sweet - when I did the heavier final coat things went pear shape. Lesson learnt - light coats for me now no more heavy top coats.
David
Dangermouse
Postby ListerStormGT » Thu Oct 25, 2012 6:33 pm
I never use Future anymore because it always yellows, not just on white but also on Gulf blue projects also. Its not right away but about 6 mos to a year I notice the yellowing starting. I have never had any problems with the Krylon crystal clear on the decals or yellowing after being on a car for over 2 yrs.
Another thing I always do is spray a light coat on the decal sheet before I use them, its not needed but I just like to do it to help give it a little extra.
Postby RichD » Fri Oct 26, 2012 6:57 am
I always put Future over decals before I shoot a solvent based clearcoat. Future is water based so it will not attack decals or paint. Future can cause some types of white paint to yellow, but I have never had a problem with Future over Testors white. Clearcoats use a mixture of solvents that might include ketone, acetone, toluene or xylene. If you use an enamel paint you have to be careful if you put a laquer clearcoat on top of it. Once I hit one side of a body with no problem, but when I did the other side the paint was damaged. Krylon Crystal Clear seems to be less likely to cause problems, but it does not resist chipping as well as products intended for automotive use. Lately I have started to coat everything with Future before I shoot the clearcoat. I have cars that have had Future on them for many years and I hace never had a problem with it turning yellow. I pour some Future into a small screw cap bottle and work from that. I never pour unused Future back into the original container.
Postby Cincyslots » Wed Oct 31, 2012 11:16 am
Ok, good news. the Krylon went on beautifully. I'll post photos in a couple days. The not so news is that the decals were made by someone else. I hope to do another car over the weekend with the Pattos and see how it works. Thanks for the tip folks. So far so good!
Bruce
Cincyslots
Postby biedmatt » Thu Nov 01, 2012 5:32 am
biedmatt
Postby VenturaAlfa » Thu Nov 01, 2012 1:34 pm
Hi Bruce,
I have Pattos, Jim Hellers, some custom made decals and some 60's and 70's Revell decals. I have found that anything placed over some of them caused them to wrinkle. What I do now is save a portion of the clear portion of the decal page and put it on a piece of scrap and then try my clear on that.
I have found it to be essential to use solve a set or micro set on the decals before any clear, including pledge with future shine. Doing that, I have not had a decal wrinkle in quite some time. I got that from my local hobby shop model builder who builds around a hundred cars a year. It certainly has saved me a lot of grief.
The first set that wrinkled on me I had paid a substantial amount to have a custom set of decals made and I had to have them remade. They look great now but that was an expensive lesson.
Ventura Alfa
VenturaAlfa
Return to The Paint Booth
