Home Racing World • View topic - What paper for laser printed water slide decals?
Custom Paint Job Showcase
Postby JamieB » Sun Mar 24, 2019 11:38 am
After doing a bit of searching I can't seem to find a good answer for this question. I have a laser printer and would like to try my hand at printing decals for my Showdown builds. Can anyone recommend a good paper for a laser printer? I found Blinggasm paper on Amazon but it has mixed reviews. I also came across Tango Papa but can't find many reviews or if they even are in business still.
Also, if anyone has any tips or trick for a first time home printer please post them here.
Thanks!
Jamie
JamieB
Re: What paper for laser printed water slide decals?
Postby PetesLightKits » Sun Mar 24, 2019 12:02 pm
PetesLightKits
Postby JamieB » Sun Mar 24, 2019 7:21 pm
Thanks for the reply, but I'm using a laser printer, not an ink jet. It looks like most of the paper other there is meant for an ink jet printer. I'm hopeful someone else on here uses a laser printer as well and can point me in the right direction.
JamieB
Postby BARC 1 » Sun Mar 24, 2019 7:38 pm
I use inkjet paper in my laser printer, and it seems Ok. Never had an issue
I print them and then spray them with a gloss coat
Postby PetesLightKits » Mon Mar 25, 2019 12:08 pm
PetesLightKits
Postby Changing-Gearz » Mon Mar 25, 2019 12:53 pm
I buy from Tango Papa. But I have an ALPS
He's a legit guy - still around... Website is probably from 1993 - but he still sells the secret sauce.
I know I've read on his site it will work with laser copiers..... Maybe get the $10 sample pack and try it.
Its half the thickness(~ish) of testers paper and therefore bends MUCH easier. Putting a clear coat on it and bending around corners may end up in a horrible mess - probably have to be careful there.
Changing-Gearz
Postby RichD » Tue Mar 26, 2019 7:45 am
Try a Google search for laser printer decal paper. I found this hit on Amazon, there is both clear and white available. https://www.amazon.com/Blinggasm-Waters ... B00ZLVF698
Postby JamieB » Tue Mar 26, 2019 2:52 pm
Thanks everyone for the input. I contacted Tango Papa today and will start with his sample sheets because its only $10 shipped for 4 sheet (2 clear and 2 white).
JamieB
Postby jimslittlecars » Tue Apr 02, 2019 2:39 pm
I use Texascraft www.papilio.com. Great for laserjets, never tried their inkjet paper
jimslittlecars
Return to The Paint Booth
