How to deal with decals wrinkles
Hi All
I would like to pick your brain and ask for some advices on how to deal with decals wrinkling after being applied.
Just to begin with I use microsol Set and Sol.
First I apply the set solution. Then put the decal on top of it until it gets to the right position.
Then, I use a flat brush to put some Sol.
As a point in case, I want to show you my latest build: a scaleauto R8 whitekit in the Korea Phoenix Racing livery for the Asia Le Mans.
In the pics below you can see on the red stripe going from wheel arch to wheel arch under the door that there are three wrinkles: two under the number 31 and one under the O.
.jpg)
And this is on the other side: there is on the red stripe under the O
When I applied the decals they were not there. After a while after the Sol application the wrinkles started to appear and never left.
If I use my finger with a bit of saliva (ok not the best decal liquid out there) the wrinkles can be pushed back but after a couple of secs they come up again.
I have cut a hole in them to make sure that there is not water but to no avail.
Any suggestions?
.jpg)
.jpg)
Any suggestions?
