Home Racing World • View topic - New Slot Cave..... Means New Paint Booth
Custom Paint Job Showcase
Postby Gameover » Fri Dec 30, 2016 1:29 pm
Before we moved i had done. Nice write up on a cheap cardboard paint booth. Well this round i bought these 2x2 plywood panels for $2.99 each and reused the light but bought a new fan for $12 since the other one was so crusty. I also added a furnace filter this time. Notice i have doors with himges. I love em. Keeps heat and fumes in. Im very happy with the result!!
The 40 sedan for shotgun my son is building into a hot rod!
And my Wise Industries Buick for the Sportsman race :)
Re: New Slot Cave..... Means New Paint Booth
Postby btaylor » Fri Dec 30, 2016 1:37 pm
Very nice Steve-o! simple and effective. might have to copy your design on that!
Thanks for sharing.
Postby btaylor » Fri Dec 30, 2016 1:48 pm
Hey Steve, build a scaled down version of this for turning the model while you paint!Image
Postby HomeRacingWorld » Fri Dec 30, 2016 2:14 pm
Great job, that's how you do it :)
Postby mattb » Fri Dec 30, 2016 2:54 pm
This is the version I built for $15 . I bought the plastic box and fan at Walmart for about $15. Furnace filters are cheap, but it does go thru them. I use 2 and replace the one in front pretty often. I have one filter taped in permanent and the another one that lays against it. The taped filter is always clean and the outer is the one I replace. P1010003.JPGP1010004.JPG
Postby RichD » Sat Dec 31, 2016 8:37 am
Here is a spray booth that I built a few years ago.
Postby Gameover » Sat Dec 31, 2016 3:45 pm
Very noce booths guys. And yes bob that would be neat :)
Postby Cincyslots » Sun Jan 01, 2017 10:11 am
what are you guys using for fans that are "spark" fire safe?
Bruce
Cincyslots
Postby RV Racing » Sun Jan 01, 2017 5:59 pm
Bruce, I use a Grainger squirrel-cage fan that locates the electric motor outside of the paint/fume airstream. The fan is connected to a duct that vents the fumes outside of the garage. I think that isolating the electrics from the fumes is important for safety when using solvent-based paints.
Rick V.
RV Racing
Postby Gameover » Sun Jan 01, 2017 6:16 pm
I just use a cheap bath fan from menards. Vented out side.
Postby RichD » Mon Jan 02, 2017 8:11 am
I used a NuTone bathroom vent fan from Home Depot, it is a non-sparking type. Downstairs the booth gets connected to ductwork that goes outside. When I use the booth upstairs I have some Lexan that fits in a window and the booth connects to that.
Postby mattb » Mon Jan 02, 2017 2:05 pm
use the cheap Walmart fan and will take my chances.
Postby TuscoTodd » Tue Jan 03, 2017 7:40 pm
I REALLY need to build one of these!
:handgestures-thumbup:
Postby Gameover » Tue Jan 03, 2017 7:59 pm
Todd you better get going :). My mode A was brush painted cause this wasnt up and running yet. All part of the patina i guess.
Postby TuscoTodd » Tue Jan 03, 2017 9:24 pm
That paint job looks right at home on the model A!
:D
Return to The Paint Booth
