Very cool two tone effect Dave!
Apparently that version is very similar to the Parma version in that if you have it on there thick, it gets a bit difficult to cut without it wanting to "pull". I found that for what I was doing, one mist coat followed by two regular coats worked well. It is more apt to tear if you aren't using a really sharp blade when it is thinner - but I found giving my blade a pass on a ceramic rod after each cut eliminated that issue and made it MUCH nicer / easier to get nice crisp lines.
I haven't used the liquid mask in a while - but it is what I used to keep my sanity and get the nice tight lines on the fender to body joints of my #7 Seagram's Racing Bug below...
It proved to be a GREAT option verses trying to tape them!!!
:D
