Home Racing World • View topic - Colorsand and re-clear? A quick "how to"
Re: Colorsand and re-clear? A quick "how to"
PostPosted: Wed Jun 22, 2016 6:13 pm
by Broman62
Fantastic tut SD...that is one high gloss shine!!! The things we learn here are utterly amazing!!!
PostPosted: Wed Jun 22, 2016 7:00 pm
That's as clear and concise as can be done, Dave. Thanks!
PostPosted: Wed Jun 22, 2016 7:07 pm
Yes sir, that covers it :)
Excellent. This goes in the garage.
PostPosted: Wed Jun 22, 2016 7:29 pm
by Dodgefarmer
Dave, that's just drop dead gorgeous. Do I understand correct that all your coats are lacquer. (primer, paint and clear). The reason that I am asking is that so far I have destroyed 2 paint jobs now with Krylon crystal clear. (ended up with an awesome krinkle finish :? )
Randy
PostPosted: Wed Jun 22, 2016 7:58 pm
by Audi1
Nice shine! Thanks for the tutorial, Dave.
I've sometimes found that dry 0000 steel wool will give the same sanding effect as 1200-1500 wet sandpaper on a clear coat. I'm always looking to save weight, so I 000, then 0000 the body (instead of using primer), hit it with 3 light coats of paint de jour, 0000 again and decal then clear. My finishes aren't like what you show..............but they're light....................... Paint weighs, you know.......... ;)
PostPosted: Wed Jun 22, 2016 8:09 pm
PostPosted: Wed Jun 22, 2016 9:13 pm
by scatman
A real beauty. Reminds me off my spit shines on my boots during my military career. :text-bravo:
PostPosted: Wed Jun 22, 2016 10:00 pm
by dreinecke
I've only been using Duplicolor for over 14 years - any will work (I do occasionally use Testors for certain colors) but find that I really like they way they lay on and the quick drying time.
Great tutorial, and one I need to do more of instead of rushing as much as I do LOL.
PostPosted: Wed Jun 22, 2016 11:35 pm
by CrockettNZ
nice one Dave :text-goodpost:
I use pretty much the same process but use a 2000 grit for the final sand
I have mostly used Tamiya lacquer
have used some other brands as they are a lot cheaper but always end up going back to the Tamiya
PostPosted: Thu Jun 23, 2016 8:07 am
by TuscoTodd
I haven't done any color sanding on any of my builds, but seeing results like that, I may just have to give it a whirl! WOW Dave - that is gorgeous!!!
On the paint, I am a BIG fan of the Duplicolor paints! I have tried others and while I have gotten some very good results with them, they haven't shown to be nearly as consistent as the Duplicolor products.
PostPosted: Fri Jun 24, 2016 12:47 pm
by Cincyslots
Awesome!!
Bruce
PostPosted: Mon Jun 27, 2016 4:11 am
by walker
What is the difference between lacquer and enamel ?
I have been using Testors Model Master enamel for decades now and never had any issues, neither with drying, hardening nor gloss.
Roland
PostPosted: Tue Jun 28, 2016 4:33 am
by walker
Thank you very much.
But smelling on my Testors enamel colours after having read your reply, I doubted a bit.
And I was right.
Here is a good explanation ( I know, I could have read it before I asked here, but I did it only now. Well... )
https://en.m.wikipedia.org/wiki/Enamel_paint
Even on the picture you see "oil based enamel".
I doubted because in my Testors "enamels" I definitely smell things that are not the typical ( color ) oil smell but solvents, just as being used elsewhere as well.
Regards,
Roland
PostPosted: Tue Jun 28, 2016 6:08 am
