Carrera Evolution 65 mustang
Custom Paint Job Showcase
Postby death on 4 wheels » Sun Aug 02, 2015 4:17 pm
What is the best way to prep this Mustang for repaint? Its yellow with black stripes. Also what is best to use for bodywork?
death on 4 wheels
Re: Carrera Evolution 65 mustang
Postby HomeRacingWorld » Sun Aug 02, 2015 4:39 pm
Soak the body in 91% alcohol until you see the stripes start to lift. Scrub with an old toothbrush. Wash in lukewarm soapy water. Use primer then your color choice.
I like using the automotive red spot putty for any type of bodywork...but most like Tamiya as well.
Postby death on 4 wheels » Sun Aug 02, 2015 5:11 pm
Okay thanks I've done custom rusted models, so I'm just wondering if it is basically the same.
death on 4 wheels
Postby death on 4 wheels » Sun Aug 02, 2015 5:17 pm
Also what is the best way to cut these bodies?
death on 4 wheels
Postby RazorJon » Sun Aug 02, 2015 5:30 pm
cut it as in stretch it or open wheel wells up?
I have a X-Acto Razor saw I use for body panels and a good die grinder with round sanding drum for opening things up
Postby death on 4 wheels » Sun Aug 02, 2015 6:04 pm
I want to add the scoop,but the factory one is in the way.
death on 4 wheels
Return to The Paint Booth
