Home Racing World • View topic - I need paint removal help
Custom Paint Job Showcase
Postby Cincyslots » Fri Nov 30, 2012 8:07 am
I messed up and I need to remove testors and tamiya lacquer paint. The typical 91% bath has not done a thing. Any other tricks before I junk the body trying goo gone?
Cincyslots
Re: I need paint removal help
Postby dreinecke » Fri Nov 30, 2012 8:23 am
Hit one of the model forums, some folks on those always have some weird idea that works in these situations.
Postby goosenapper » Fri Nov 30, 2012 8:24 am
goosenapper
Postby dreinecke » Fri Nov 30, 2012 8:33 am
Brake fluid also works pretty well as I recall from my old model days and Deslotted just used it on his thread.
Postby HutchTrickStar » Fri Nov 30, 2012 8:41 am
Yes, brake fluid works well (Standard DOT 3). Tire bleach will do the trick too. I never had either cause adverse effects on plastic models.
HutchTrickStar
Postby Cincyslots » Fri Nov 30, 2012 8:58 am
thanks fellas. what do you do to get rid of the brake fluid once you're done?
bruce
Cincyslots
Postby Scatman1 » Fri Nov 30, 2012 9:03 am
Bruce, here's a link with a lot of info. http://www.paintingclinic.com/clinic/gu ... paint3.htm
I use to use Chameleon but it is hard to find. It was safe and removed everything.
Scatman1
Postby Cincyslots » Fri Nov 30, 2012 9:14 am
thank for the link. well, since i need simple green anyhow, i'll try that. I'll let you know what happens.
thanks,
bruce
Cincyslots
Postby waaytoomuchintothis » Fri Nov 30, 2012 11:40 am
The only time I ever had any trouble stripping any kind of paint that I put on was the time I used ordinary isopropyl instead of 91% isopropyl. When I learned better on HRW, stripping was a breeze on my painting, and harder on factory jobs. Even then, after 24 hours, I could scrape it off with my fingernail easily, then soak a few minutes then go back to scraping, etc. Tesors and Tamiya lacquers are easily removed in alcohol in a short time with 91%, but enamels are a totally different situation. Is there any chance you are dealing with enamels or an enamel clearcoat like Scaley uses in white kits?
Postby Cincyslots » Fri Nov 30, 2012 12:26 pm
nope, no chance they are enamel. i learned that lesson.
bruce
Cincyslots
Postby goosenapper » Fri Nov 30, 2012 12:32 pm
goosenapper
Postby waaytoomuchintothis » Fri Nov 30, 2012 2:18 pm
I don't know, that is a quart bottle and I don''t use much at a time. Maybe that would work out okay. It is caustic soda in some dilution, so care and a little high school chemistry would help a lot with safety. I think I'm going to try it. After all, I would only use it for the most stubborn stuff, after 91% isopropyl had failed.
Postby HomeRacingWorld » Fri Nov 30, 2012 3:16 pm
Just send it to Cagee. He LOVES wet sanding bodys. I am sure he can sand it perfectly clean for you...and best part is no greasy kid stuff.
Buy him a bowl of 3-Way chili, fair deal.
Postby smallblockhero » Fri Nov 30, 2012 5:12 pm
have you tried letting it soak in brake fluid for 24 hours? a qt of brake fluid cost about 4 bucks and will remove almost any paint and the leave the plastic perfect. check my strombecker redux thread.
smallblockhero
Postby Cincyslots » Fri Nov 30, 2012 10:25 pm
6hrs of simple green and no dice. if it doesn't come of by tomorrow afternoon, brake fluid baby! at this point I should hve just bought another car and started over. :?
bruce
Cincyslots
Return to The Paint Booth
