Bugeye Sprite build 7
Postby VTECFOUR » Sun Jan 11, 2015 7:10 pm
Got a stock Bugeye build with a metal chassis going.
Re-worked my last set of BWA front and rear scratch built brackets with 3/32 square brass main rails and .032 strips for bracing and body mounts.
As usual, Ranch Design rims and Paul Gage tires for motion.
Munter resin body provides cover. Going for an understated look with hard interior cover, single hoop roll bar and wire wheel inserts.
You can't have too many Bugeyes.
VTECFOUR
Re: Bugeye Sprite build 7
Postby btaylor » Sun Jan 11, 2015 7:15 pm
Really liking this car!. I have one in the works myself,and I might steel some ideas here!
Postby munter » Sun Jan 11, 2015 10:36 pm
The legend lives on, that is your legend not mine.
Postby FootScoot » Mon Jan 12, 2015 6:41 am
Great build as usual. What Ranch Design wheels did you use, and what PG Tires? I think those would work for a Mini build I have going. Too bad BWA doesn't make those chassis pieces anymore. :)
Postby munter » Mon Jan 12, 2015 12:09 pm
Footscoot, there is a guy in Australia who is making brackets that are almost identical.
User name is Camber on Auslot forum.
I bought five. They look almost identical.
Postby VTECFOUR » Mon Jan 12, 2015 2:03 pm
The rims are custom made ones that Steve at Ranch did for me awhile back. They're designed to fit the .375 BWA wheel inserts. Just ask him for the Cortina file ones. The Paul Gage tires are sized 20084, I believe.
I have used this combination on most of my classic small car builds.
I'll have to check out those brackets from Camber.
VTECFOUR
Postby Ember » Mon Jan 12, 2015 3:39 pm
Small cars rock. Looking forward to seeing where you take this little Sprite.
Postby FootScoot » Mon Jan 12, 2015 6:33 pm
Thanks Dan. I will be ordering some of those wheels, and chassis pieces. You can never have too many small cars. :)
Postby dreinecke » Mon Jan 12, 2015 8:07 pm
The chassis is a beauty, but that line up is spectacular!
Postby VTECFOUR » Tue Jan 13, 2015 5:12 pm
Some progress.
Got the chassis rolling with a BWA FF050 motor, Slot It 9t pinion, SCX Pro 26t crown and MB Slot guide.
Body's mounted using Dart Hobby 2-56 screw holders in plastic tubing allowing adjustability for body rock.
Runs just fine on my little test track.
A bit of modeling done too with the driver figure opening in the hard interior cover.
Stance is just right for me.
VTECFOUR
Postby dreinecke » Tue Jan 13, 2015 11:20 pm
Dan - the stance is perfect! That cover looks great too.
Postby VTECFOUR » Wed Jan 14, 2015 8:24 pm
Modelling progress with a driver figure and hoop roll bar test fitted and BWA two-prong wire wheel inserts glued in.
Test ran on Luf's Targa Burnaby and a bit more front weight needed.
Body paint in Tamiya AS-19 Intermediate Blue is next.
VTECFOUR
Postby VTECFOUR » Sat Jan 17, 2015 2:55 am
Primer's on.
Final coat this weekend.
VTECFOUR
Postby Gameover » Sat Jan 17, 2015 3:03 am
Love the bus/transporter!
Postby VTECFOUR » Tue Jan 20, 2015 2:16 pm
Pretty much done.
Now, back to the VW bus project.
VTECFOUR
