Dodge Daytona.....LMP?
Postby dge467 » Sun Nov 11, 2012 5:00 pm
Well not really! I've had this Carrera Daytona body hanging around for a while needing a chassis, and I also had a Scalextric Peugeot LMP with a damaged body. The wheel base was just about perfect between the two, so why not stick the chassis under the Dodge. I radius the wheel openings to get the body to sit low on the chassis. If you look behind the nose cone on the Carrera Daytona there is a couple of tunneled areas behind the head light buckets, so I cut that area out on the body for using the lights on the Peugeot chassis. The tunneled area is not as big as the factory pop up headlight, that is why they aren't cut out all the way. I used Bare Metal Foil and chrome paint for reflectors in the head light. Kristal Clear was used for the head light lenses. I also cut open the tail lights and used clear plastic painted with red translucent paint for the lenses. The interior is a flat piece of sheet plastic with a driver from the spares box, and the roll cage from a 1/32 stock car kit. I used Testor's Plum Crazy lacquer paint and clear coat. Trim is done with Bare Metal Foil. I still need to number and letter the car. This was another fun project that cost no money by using parts and pieces that I had kicking around. Sorry for the dark pictures.ImageImageImageImage
Re: Dodge Daytona.....LMP?
Postby dge467 » Sun Nov 11, 2012 5:02 pm
More pictures.ImageImageImageImageImage
Postby waaytoomuchintothis » Sun Nov 11, 2012 5:20 pm
Plum Crazy. Dead on perfect. I remember that color on Challengers, too. Gorgeous model. I bet it flies, too.
Postby ListerStormGT » Sun Nov 11, 2012 6:58 pm
That looks great! Looks pretty good with the fenders opened up for the tires. Nice job :clap:
Postby Dodge Fan » Sun Nov 11, 2012 8:52 pm
That looks great. like the paint and smooth finish.
Dodge Fan
Postby baford1 » Mon Nov 12, 2012 1:28 am
looks good a modern look on a classic
Richard
baford1
Postby eeprof » Mon Nov 12, 2012 6:32 am
Looks good!!!
I like the lights!!!
Greg
eeprof
Postby Florida_Slotter » Mon Nov 12, 2012 8:22 am
Simply put . . . . . . . .
Postby TsgtRet » Mon Nov 12, 2012 3:05 pm
I bet if this went to Barrett-Jackson they'd call it a "resto-mod". Hard to put my finger on what is so appealing about it......it just looks "right". Beautiful job, sir! :clap:
Postby jmsh54 » Mon Nov 12, 2012 7:59 pm
Greetings, very nice ride. Love the color and your modifications. Regards, John
jmsh54
Postby rbianchi » Mon Nov 12, 2012 8:23 pm
Boy, it does look good. That is not a combination that I would have thought to use but it really works. You could go cruisin'
for chicks with that 8-).
rbianchi
Postby dge467 » Mon Nov 12, 2012 9:08 pm
Thanks for the compliments! I wasn't sure of keeping the wheels, but they kind of grew on me.
